How Can You Solve a Complex Numerical Integration Problem on Paper?
samgrace
Integreate:
##T = ∫ \frac{dy}{V_ab (y)} = \frac{2}{v}∫[1 + \frac{\alpha^2 y}{L} + 2\alpha \sqrt\frac{y}{L} cos(\phi(y))]^\frac{-1}{2} dy##
where ## \phi (y) = \frac{\pi}{6} + sin^-1(\frac{\alpha\sqrt{y}}{2\sqrt{L}}) ##
The limits are between 0 and L
I have input this integral several times into MATLAB with no success, I was wondering if there was a way to do this on paper? My module on numerical integration isn't until next term
Are you familiar with a function known as ##\text{quad()}##? It uses Simpson quadrature to numerically estimate the integral.
There is also ##\text{quadl()}##, which uses Lobatto quadrature.
The quad/quadl syntax you should be using is: ##\text{quad(function, a, b)}##.
So define your integral as an anonymous function between the respective limits from ##a## to ##b## and quad should return the answer.
samgrace said:
Integreate:
You can use the fact that
[tex]\cos(\phi) =\frac{\sqrt{3}}{4} \sqrt{4 - \frac{\alpha^2 y}{L}}- \frac{\alpha}{4} \sqrt{\frac{y}{L}}[/tex]
then change variables to ##y/L = w^2## to get
[tex]T = \frac{2}{v} 4L \int_0^1 \frac{w}{\sqrt{D(w)}} \, dw, \\<br /> D(w) = 4 + 2 \alpha^2 w^2 + 2 \sqrt{3} \alpha w \sqrt{4 - \alpha^2 w^2}[/tex]
A further change of variables to ##w = (2/\alpha) \sin(\theta)##, followed by ##\theta = \lambda/2## produces
[tex]T = \frac{2}{v} \frac{2L}{\alpha^2}<br /> \int_{\lambda =0}^{2\arcsin(\alpha/2)} \frac{\sin(\lambda)}{2 - \cos(\lambda) -\sqrt{3} \sin(\lambda)}\, d \lambda[/tex]
This last integral still might not be doable explicitly, but it contains a single parameter ##r = 2 \arcsin(\alpha/2)##, so can be tabulated as a numerical function of ##r## (and perhaps even be "fitted" by a simple functional form in ##r## that has adequate accuracy over the ##r##-range of interest to you).
Note added in edit: by some further manipulations, the integral can be done in terms of standard functions. I really cannot tell you more until you supply evidence of having struggled with the problem, by showing your work, etc.
