How Can You Solve for x in Complex Elastic Collision Equations?
  • Level: High School
  • Thread starter Thread starter luckis11
22 replies · 2K views
luckis11
Poster has been reminded to use LaTeX to post math equations on PF.
(Tsinα)^2+(u+Tcosα)^2=((1+μ/m)((μu^2-μx^2-m((u-x)m/μ)^2)/(μ+μ^2/m))^0.5+Tsinα)^2+(Tcosα+(u-x)μ/m-x)^2
Can you isolate x? I.e. x=...
It's for elastic collision of unequal masses under angle of impact α.
Mathematics news on Phys.org
You haven't used LaTeX so your equation is very difficult to read, but it looks like a rather messy quartic.
You've flagged this as A level, meaning that you have postgraduate knowledge of the topic. Is that correct?
Oh, wait, there is a square root in there somewhere... You make us work for it ;) But I would start to clean things up a bit by collecting all terms of x, then collect all terms not containing an 'x' and give it some other name. Then it is much easier to read.
$$(Tsinα)^2+(u+Tcosα)^2=\left((1+μ/m)\left(\frac{μu^2-μx^2-m((u-x)m/μ)^2}{μ+μ^2/m}\right)^{0.5}+Tsinα\right)^2+(Tcosα+(u-x)μ/m-x)^2$$
Like this?
Combine random constants:
$$a=\left(b\left(f+gx^2+hx\right)^{0.5}+c\right)^2+(d+ex)^2$$
You can expand the first square, then isolate the square root, square the whole equation, and you get a quartic equation, which has a closed solution but it's really awkward.
I isolated the square root so got rid of it by squaring both sides of the equation, but I got (28 factors)^2=27+26+...+1 factors. So it's helpless.
I don't think you mean factors (or helpless). I think you mean terms.
Anyway, " (28 factors)^2=27+26+...+1 factors " doesn't have an x in it, so we don't know where you are. It does not look like you followed mfb's path.
Continuing with @mfb's equation. If I haven't made a mistake:
\left[ \left(\sqrt{a - (d+ex)^2} - c\right)/b \right]^2 = f + gx^2 + hx
then
\left(a - (d+ex)^2 + c^2 - 2c \sqrt{ a - (d+ex)^2}\right)/b^2 = f + gx^2 + hx
Expanding the terms in the square root will leave a ##\sqrt{x}## term. So it is not a quartic... I wouldn't know how to solve this.
Bring everything except the square root onto the right hand side, then square. You will hAve a quartic.
Oh, whoops, you are right :). I wasn't paying attention. I thought my second equation already had powers of four in x. (that happens when you are doing things simultaneously...)
In case you simply want an expresson to work with, you can solve for x in Mathematica easily:
[CODE title="Mathematica"]In[15]:= mySol[a_, d_, e_, c_, b_, f_, g_, h_] =
x /. Solve[(a - (d + e x)^2 + c^2 -
2 c Sqrt[a - (d + e x)^2])/(b^2) == f + g x^2 + h x, x];
mySol[1, 2, 3 + I, 4, 5, 6, 7, 8] // N
Out[16]= {-0.61495 - 0.545281 I, -0.559976 + 0.594679 I, -0.577998 +
0.710359 I, -0.56296 - 0.727542 I}[/CODE]
I do not know this, what am I supposed to do with
I don't think that explicit solution is too relevant since it seems that for the chosen values of a to h all solutions have an imaginary part.
But if you want a solution then you have to do some of the work yourself. Start with the equation in post #9 and apply the hint in post #10. Then you'll have your quartic and can solve it using the equation in the wiki link in post #4.
Ι told you I "solved" it but it has >27+26+...+1 terms. I don't see how imaginary numbers can help, can they? However, I do not have the equation of the op any more, I deleted it. I hope it's the same as the one I have now.
I moved the thread from the calculus forum to general math and reclassified it as level B as it's just a complicated algebra problem.
The answer with imaginary numbers aheight mentioned is top level my friend.
  • Skeptical
The fact that a solution you found involves complex numbers does not make this question a "top level" (i.e., A = post grad) type of problem.
The same as it was in messages 12, 13, 15, 17 and 18.
luckis11 said:
So what's the solution with complex numbers.
It's impossible to say since you didn't define what any of the quantities are. But if you were expecting a real root, a complex result usually means the equation you started with is wrong.
Yes.
Don't bother, I solved it. Not exactly that equation, but a similar I have now.
