How do E[X] and E[|X|] relate?
  • Context: Undergrad
  • Thread starter Thread starter MidgetDwarf
6 replies · 3K views
MidgetDwarf
TL;DR
For expectations of random variables. Relationship between E[X] n E[|X|]?
Greetings,
I am studying probability theory [non-measure theory] from a textbook.
I stumbled to the topic stating that Cauchy Distribution has no moments.
It was not proved, and I tried working it via direct calculation of the improper integral of E[X^n] for the case n=1.
Anyhow, I wanted to generalize this without success. I stumbled upon this thread here:
I really enjoyed the proof given StoneTemplePython. However, I am unsure of the following:
Why does E[|x|] diverges implies E[x] diverges?I believe this is the crux of the poof. Since it assumes, in my understanding, that having shown E[|X|] diverges, then applying the comparison test for improper integrals in the last line of that thread, then E[|X|^n] diverges.
How does this relate to E[X^n]?
. My hunch tells me that it has something to do with f is integrable iff |f| is integrable, and how we can decompose |f| into the positive and negative parts of f?
My knowledge of Measure Theory is very poor. So hopefully someone here can why.
Integral for even n diverges clearly to plus infinite. Integral for odd n is zero for integrand [-L,L]. However we do not have such a constraint thus the integral diverges plus or minus.
FactChecker said:
Let ##X_-## and ##X_+## denote the negative and positive parts of ##X##. Then ##E[X]=E[X_+]+E[X_-]## and ##E[|X|]=E[X_+]-E[X_-]##. If ##E[|X|]## is infinite or undefined, then one or both of ##E[X_+]## and ##E[X_-]## are infinite, so ##E[X]=E[X_+]+E[X_-]## also diverges.
I'm not sure about the higher orders, ##E[X^n]## for ##n\gt 1##. If ##X## is restricted to ##|X| \lt 1##, then those moments may exist.
Thank you fact checker!
I now understand that the proof given was using the measure theory [lebesgue integral] formulation of probability.
the decomposition of E into its positive and negative parts comfirmed my hunch.
from my understanding, E[|X|] exists iff E[X] does using lebesgue integral. Since it comes from the fact that f is integrable iff |f| is integrable.
This is not necessarily true under the Reimann Integral. Ie., E[X] finite does not imply E[|X]|] is finite.
For this to hold true it seems to me there also needs to be a requirement along the lines that ##X_+## has same "cardinality" or "density" as ##X_-##?
E.g. for a finite sequence of ##N = P + M## numbers, ##P## non-negative and ##M## negative, I would expect the relation to be ##N E[X] = P E[X_+] + M E[X_-]##.
I wouldn't say that necessarily depends on the type of integral. Lebesgue integration allows you to talk about integration in a more general context, but it is easy to use this with either integral method. That being said, I do not know what treacherous details would be required in a formal proof.
Yes, it is a simple step in that direction.
That may be true. I am too rusty on this to say. It would depend on how the limits are defined. I would say that if ##E[|X|]## is infinite, with both positive and negative parts infinite, then the value of ##E[X]## depends on how limits are taken.
I will have to leave this discussion for those who are more knowledgeable.
The contraposition: "E[ X ] converges thus E[ |X| ] converges" seems easier to handle.
$$ E[|x|]:=\int_{-\infty}^{+\infty} f(x)|x| dx = -\int_{-\infty}^{0} f(x)x dx + \int_{0}^{+\infty} f(x)x dx = E[x]-2 \int_{-\infty}^{0} f(x)x dx $$
As a finite value cannot be divided into two infinites, ##\int_{-\infty}^{0} f(x)x dx## is finite thus E[|x|] is finite.
Notice that the integral $$\int_0^1 f(x)dx$$ converges for the Cauchy density. Now, for x larger than 1 $$1+x^2 < 2x^2$$ so $$\frac 1 {1+x^2} > \frac 1 {2x^2}$$
This means that for ##n \ge 2## you have $$\frac{x^n}{1+x^2} > \frac{x^n}{2x^2} = \frac{x^{n-2}}{2}$$, so ## n - 2 \ge 0##, and since $$\int_1^{\infty} x^k dx$$ diverges when ##k \ge 0## you've shown $$\int_0^{\infty} x^n f(x) dx$$ diverges for ##n \ge 2##.
For the integral over the negative portion of the number line apply that sort of argument to ##|x|^n##.
Of course since $$\int_{-\infty}^{\infty} f(x) dx$$ is defined as $$\int_{-\infty}^{0} f(x) dx + \int_{0}^{\infty} f(x) dx$$ (I could have used any number other than $0$), since the integral over the positive portion diverges the entire integral diverges.
