- 9
Xnn said:So, how high up in the atmosphere does the lapse rate apply? Obviously, it doesn't apply all the way to the moon since that would imply impossibly low temperatures. Instead, it only applies to the elevation at which there is no longer any significant water vapor and that elevation in turn is dictated by the level of CO2, CH4 and NOx in the atmosphere and the amount of heat being transferred.
Actually, the lapse rate applies up to the tropopause; and that is determined not by the presence or absence of water vapour, but by whether there is net heating or cooling from the effects of radiation transfers. Water vapour actually works to reduce the lapse rate, because the moist adiabat is significantly weaker than the dry adiabat.
A dry atmosphere has a much stronger lapse rate. But whether dry or moist, the lapse rate applies up until the atmosphere is back in a radiative equilibrium, and this transition marks tropopause, the end of vertical convection, and the start of the stratosphere (stratified) in which the "lapse rate" is governed by completely different principles, of radiative equilibrium rather than of adiabatic convection and radiative-convective equilibrium.
The theory of lapse rate and tropopause height is explained in Principles of Planetary Climate, in section 4.8 "Tropopause height for real gas atmospheres" (page 255). The theory is general, and applies for all kinds of atmospheres and planets. Other texts on atmospheric physics should explain the same ideas; I am consistently referring to this text (PoPC) primarily because it is online and easily accessible as a common reference point for discussion. There is a progression of material; dipping into a section will give useful conclusions; and for deeper understanding it's well worth working through the previous chapters.
In brief, if works like this. In the absence of any convection or conduction of heat, where the only energy flux is from radiation, we expect a sharp discontinuity in temperature at the surface. The so called natural "skin temperature" of the atmosphere is 2-0.25 = 0.84 times the surface temperature. (See PoPC section 3.6 "Optically thin atmospheres: The skin temperature" page 141.) This is of course unstable; and there is a flow of heat up into the atmosphere from the surface by convection, and a natural temperature gradient is formed based on adiabatic energy transfers, up until the skin temperature is reached. In this region, the atmosphere is in "radiative-convective equilibrium", with net cooling of the atmosphere from radiation balanced exactly by net heating from convection. See also figure 3.14 from PoPC.
Above the tropopause the atmosphere is in a pure radiative equilibrium. I have also given some more discussion, with some extracts from PoPC, in other posts. See, for example [post=2311418]msg #154[/post] of thread " Need Help: Can You Model CO2 as a Greenhouse Gas (Or is This Just Wishful Thinking?)", and surrounding discussion.
Cheers -- sylas
