How Do I Adjust a Formula to Alternate Sequence Terms?
5 replies · 2K views · last reply
whatlifeforme
I am trying to solve this problem and need help with one aspect.
sequence: 0,-1,0,1 -- repeated.
How do I make every 4th term of the sequence a negative number?
for instance i have: (1 + (-1)^n)/2 but i don't know how to alternative the -1 term in.
What functions are you willing to use.
This can easily be done with sine or cosine .
You can probably come up with some solution using the "mod" function.
please explain how i would implement cosine or sine.
Try sin (n*pi/2) and add integer constants to n to shift the series.
then you are going 1, 0, -1, 0. (so if i put sin(pi/2 + npi/2) into the ratio, then i multiply by negative 1 the correct number of times, but what about the zeros? sinx=0 ---> v(sinx) = 0
So, it appears you're starting with n = 1 .
Why is it that you say that [itex]\displaystyle \ -\,\sin\left(\frac{\pi}{2}+\frac{n\pi}{2}\right)\[/itex] doesn't work ?
