What Happens to di/dt When a Switch in an Inductor Circuit Opens?
  • Thread starter Thread starter hobbs125
2 replies · 16K views
hobbs125
A circuit has a 10v battery, an 1 henry inductor, and a switch connected in series. The circuit's total resistance is 10k ohms. If the inductors maximum current is 1mA and the switch is suddenly opened how do I calculate di/dt?
Wouldn't the open switch be an infinite impedance and produce infinite voltage across the inductor?
V=L x di/dt
Not sure where to even start?
first consider the switch is closed and current is flowing at steady rate(think about it, why it should flow at a steady rate? if u don't know it already), the value is given as 1mA. u can also calculate it from given data (how?), had it not given.
now consider the switch is suddenly open. the physical consideration should be, the applied voltage is zero (and not the resistance is infinity. why?).
now set up the ckt eqn. considering potential drops across the inductor and the resistor and applied voltage zero. solve the differential eqn (u will need the value i initial = 1 mA here). and find i as a function of t. put the given values for inductor and resistor and find di/dt by differentiation.
