How do i choose the Surface area vector in different cases?
11 replies · 2K views · last reply
Neolight
Suppose we have a Electic field, E (vector) = kr2r(vector). Find the total charge contained in the sphere of radius R centered in the origin.
solution-
here E can also be written as kr3r∧, where r∧ is the unit vector
this is the given question , so obiously the best way to solve this is to use Gauss Law but while using it i have a confusion on which surface area vector to choose..
since gauss law is
∮E.ds = Qenclosed/ε°
this is where my confussion starts ,ds(surface area vector in spherical polar ) = r2sin(θ )drdθdΦ
but here the area element and E are in dot product so i have to use vector form of ds
since this is a sphere the area vector will be directed along the radial line so
ds(vector) = r2sinθdθdΦ r∧
so after putting this in the equation and doing dot product i get
∮(kr3 )( r2sinθdθdΦ =Qenclosed /ε°
therefore
Qenclosed = ε° { ∮ kr5 sinθdθdΦ
so after integration we get
Qenclosed = 4πε°kr5
but somehow in the answer given in the book it is
4πε°kR5
what am i doing wrong here ? please help
is there a mistake in the selection of area vector?
If you want to find the total charge inside a sphere of radius R, what should you choose for the radius r of your Gaussian surface?
You are confused about r versus R, right?
How are you defining r there? What surface will you integrate over?
Yes.. I know there is something wrong with what I'm doing .. but just can't get what it is
well r as the radius of a gaussian sphere where r>R..
You did not answer my questions.
That's all well and good if there are no additional charges in the shell between r and R.
the thing I'm confused is that area vector, since the problem is for a sphere we need to take spherical coordinate since it will be much more easier.
and the area vector i used here is directed towards the radial direction as dr=0 ( here is what's confussing me) .. if we take this form that the answer comes in the format where there is (r)...
solution-
since gauss law is
therefore
Qenclosed = 4πε°kr5
4πε°kR5
You could also use
$$\oint_{S_R} \mathbf{E} \cdot d\mathbf{S} = \int_{B_R} \text{div}{\mathbf{E}} \, dV ,$$
where ##B_R## is the ball of radius ##R##, ##S_R## is its surface and ##dV## is the volume element.
m
Ray Vickson said:
You could also use
ok i'll try that , but what do u think about the surface element i took was it correct method?
Neolight said:
m
Sure, it is OK.
I assume your "i" means "I" (not ##\sqrt{-1}##) and that your "u" means "you". Please avoid textspeak in this forum.
Ray Vickson said:
Sure, it is OK.
:smile::smile: sorry about that , I won't make that mistake next time
