cshum00
- 215
So i made up this simple setup:
I have a √(2) meter stick slanted on a friction-less surface on a 45° angle. And i want to determine the final x and y positions of the points A and B.
For point A:
A.1) Solving for ax
\sum F_x = T_x = F_xTcos(\theta) = ma_xa_x = \frac{Tcos(\theta)}{m}
A.2) ay=0. It is zero because the surface does not allow point A to move downward.
For point B:
B.1) ax is the same as point A because both move on the x-axis at the same rate.
B.2) Solving for ay
\sum F_y = T_y - F_g = F_yTsin(\theta) - mg = ma_ya_y = \frac{Tsin(\theta)}{m} - g
Then how do i compile these accelerations into the kinematic equations? Assuming that:
-The initial velocity v0=0 for both axis and points
-The initial position of point A is A0(x,y)= (10,0)
-The initial position of point B is B0(x,y)= (11,1)
-The initial angle θ0=45
I know that θ is my variable since the angle will become smaller all the way to zero. But i also see that the tension T on the stick also varies with the angle. So i have no idea how to move from here.
For point A:
A.1) Solving for ax
For point B:
B.2) Solving for ay
