How do I find eigen vectors for a repeated root case in linear systems?
9 replies · 2K views
2slowtogofast
i am trying to study for a DE test and was wondering if you could help with some problems
dY = -2 1
dt 0 2
i found the eigen values to be lamda = 2
i need some help on how to find the eigen vectors is this a reapeted root case and if it is how do i start off
would i go AV = (lamda)V then solve form there and in this case there would only be one eigen vector. I aplolgize on my lack of knowledge on typing in math symbols.
The eigenvalues aren't both 2. There are two linearly independent eigenvectors. Try that again.
i will give it another go
if i subtract the identiy matrix multiplied by lamda from
-2 1
0 2
i get the new matrix
( to make this simpler I am going to use L for lamda)
( -2 - L ) 1
0 (2 - L)
then if i take the determinate of this matrix and set it equal to zero i get
(-2 - L)(2 - L) - 1(0) = 0
L^2 - 4 = 0
L^2 = 4
L = 2
i must be making a mistake somewhere can some point out where thanks for the help
Stop with (L-2)*(-L-2)=0. It's already factored. The roots are +2 and -2. Likewise for L^2=4.
ok thank you so then +2 and -2 are my eigen values thank you for the help
using those values i calculated the following eigenvectors.
AV = LV
from this i get the equations
-2x + y = 2x and 2y = 2y then i get
y = 4x and y= y
if i let x = 1 i get
V = 1
for my first eigen vector
then for the second i get
AV = LV then i get the eqns
-2x + y = -2x solving i get y = 0
and the other eqn is 2y = -2y I am a little confused on how i can get my eigen vector from these two eqns. y = 0 but how can i get the x val
You've got that y=0 and x=anything. There's no equation for x. Pick an 'anything'. like x=1. That's works doesn't it?
ok i was kinda thinking that but was a little unclear but thank you. the next part i am working on is for each eigen value pick an associated eigen vector V and determine the solution Y(t) with Y(0) = V
could you please help me start this one off I am confused on that an what it meanse to pick an eigen vector can't i just use the ones from the prior part.
Ok, pick (1,4) (I'll write the vectors that way instead of in column form). Assume the solution has the form (1,4)*w(t) (where w(t) is an ordinary function, not a vector). Substitute that into the DE. Can you solve for w(t)?
