How do I find the necessary force to start a crate moving on a rough floor?
The problem involves determining the force required to initiate the movement of a crate on a rough floor, considering the effects of static friction and the angle of applied force. The crate has a mass of 32.0 kg and a coefficient of static friction of 0.600.
  • Mixed
  • Participants discuss the setup of free-body diagrams and the equations of motion for both vertical and horizontal directions. There is an exploration of how the normal force is affected by the applied force at an angle.
The discussion has progressed with participants clarifying the relationship between the normal force and the forces acting on the crate. Some guidance has been provided regarding the equations needed to relate the forces, although there is still some uncertainty about the correct application of static friction.
Participants note that the normal force is not simply equal to the weight of the crate due to the angle of the applied force. There is also a distinction made between static and kinetic friction coefficients in the context of the problem.
JennV
To move a large crate across a rough floor, you push on it with a force F at an angle of theta=21.0 degrees below the horizontal. Find the force necessary to start the crate moving, given that the mass of the crate is 32.0 kg and the coefficient of static friction between the crate and the floor is 0.600.
Fcos(theta)=Coefficient of static friction*mg
F= [(0.600)(32)(9.81)] / cos(21)
F= 202N
I entered this answer, but the system says that it is wrong and it told me that "the normal force is not equal to the weight here." So I am not sure what I'm doing wrong, but I'm close to the right answer?
Thank you very much.
Start by drawing a free-body diagram for the crate and then tell us the equation of motion you get for the crate for the vertical direction.
Vertical direction: N=mg-Fsin(theta) ?
Not quite. You know N points up, mg points down, and the vertical component of F, F sin θ, points down. So sum these forces and set it equal to 0. What equation do you get?
0=N-mg-Fsin(theta) ?
Right! So if you solve for N, you get N=mg+F sin θ. Hopefully that makes sense to you. Since you're pushing down on the crate, the ground pushes back up with more force.
So N is the necessary force to move the crate?
No, N is the normal force. It's the force the ground exerts on the crate. To move the crate, you have to overcome the force of static friction. The maximum amount of static friction, in turn, depends on the normal force, so you had to find the normal force first.
But the Force for Fsinθ is unknown...
Yes, so you're going to have to do a bit more math to get the answer. So far you have the equation for the vertical direction. What equation do you get for the horizontal direction?
In the horizontal direction the forces that act are; applied force, static friction.
So 0=Fcosθ-(uk*Fn) ?
Use either N or Fn to denote the normal force, not both. Also, it's static friction, right? So you want μs, not μk.
You have these equations:
0 = N - mg - F sin θ
0 = F cos θ - μsN
Solve for N in the first equation and plug the result into the second equation. Then you'll be able to solve for F.
0 = F cos θ - μsN
Thank you so much for helping me. =) I finally got the answer correct.
