How do i find the range of this function?
  • Thread starter Thread starter jd12345
    Function Range
The discussion focuses on finding the range of the function y = (cos2x - 1) / (cos2x + cos x). Initial attempts involved cross-multiplying to form a quadratic equation, leading to a conclusion that the range might be all real numbers, which is incorrect. It is emphasized that the range of cos x is restricted to [-1, 1], and thus the method needs adjustment, possibly by using tan or cot functions. Simplifying the equation through factoring is suggested as a more effective approach. Ultimately, the correct range must consider the restrictions imposed by the cosine function.
jd12345
Find the range of y = (cos2x - 1) / ( cos2x + cos x )
Well i tried the usual method. I cross multiplied and got a quadratic equation in cos x. Then it should have discriminant greater than zero so in the end i get (y-2)2 > 0 which is true for all y. So range is R? ( I don't have the answer)
Is the formula given correct? Do you really mean
y= \frac{cos(x)-1}{2cos(x)}?
That is equal to
\frac{1}{2}- \frac{1}{2cos(x)}
Since 2cos(x) is never larger than 2 or less than -2, 1/(2cos(x)) is always larger than 1/2 or less than -1/2, never between.
Try factoring the equation, you should get a nice simplification.
But when you simplify you need to keep in mind that if you have an expression of the form y=\frac{ab}{b} then when you simplify to y=a, you need to keep in mind that b\neq 0, so you would have to exclude this value if it's in the range.
The problem with your method is that since cos is a restricted function, its own range is only between [-1,1]. To use your method, the equation should be in tan or cot functions since they have range R. Or you can restrict the answer you get accordingly to the range of cos.
An easier method would be to factorize the equation since it results in a very simple equation.
Edit : just noticed Mentallic already posted the easier way.
Simplify \displaystyle \frac{\cos^2(x)-1}{\cos^2(x)+\cos(x)}\ .
Factor the numerator & the denominator, then cancel, keeping in mind what Mentallic & Infinitum mentioned.
  • · Replies 23 ·
  • · Replies 16 ·
