How do I make the resultant vector equal zero?
3 replies · 12K views · last reply
Ohoneo
Three forces are applied to an object, as indicated in the drawing. Force 1 has a magnitude of 33.0 Newtons (33.0 N) and is directed 30.0° to the left of the +y axis. Force 2 has a magnitude of 26.0 N and points along the +x axis. What must be the magnitude and direction (specified by the angle θ in the drawing) of the third force 3 such that the vector sum of the three forces is 0 N?
There is a drawing included, that I can post if it's wanted. Otherwise, Force 3 extends left along the x-axis as well as left along the y (making it negative?)
I'm guessing just Ax = A cos theta and Ay = A sin theta. Oh and tan^-1 = Ay/Ax
First, Force 1 = A, Force 2 = B and Force 3 = C.
So, I found the combinant vectors for A and B.
For A:
Ax = 33 cos 30 = -28.57 (negative because it is heading left along the x-axis)
Ay = 33 sin 30 = 16.5
For B:
Since B simply extends right along the x-axis, Bx = 26 and By = 0
So, I found that Rx (resultant vector of A+B) was -2.57, and Ry = 16.5
So, basically, Cx would have to be 2.57 and Cy would have to be -16.5.
Is this right so far?
However, it asks me for the total magnitude, and without the angle, how do I find that?
Then, how do I find the angle? I could use the formulas above but it appears, to me, that I'm missing a piece of information.
Any help is much appreciated :)
sorry we can't understand the question.
is the force 30o towards X or Z axis.
well i can tell you that write eqns in form of x(i) + y(j) + z(k)
and the vector opposite the resultant of vectors given in question is the answer
sorry, it's hard to understand you. Let me show you a picture of the problem, and the exact text I was given:
[URL]http://imgur.com/jwS54[/URL]
I tried the problem again and got this:
For ease, we will say Force 1 = A, Force 2 = B and Force 3 = C
Ax = A cos (theta)
Ax = 33 cos (30) = 29, but we make it negative because the drawing shows that Force 1 extends left along the x-axis, so Ax = -29
Ay = 33 sin 30 = 17
From the drawing, we can conclude that Bx = 26 and By = 0, because Force 2 only goes along the x-axis and does not move vertically.
The resultant vector components of those two forces is Rx = -3 and Ry = 17.
Now, in order to make the magnitude zero, wouldn't the x and y components of C (force 3) simply be the same as the components of the resultant vector, but with opposite signs?) What I mean is, wouldn't Cx = 3 and Cy = -17?
I think this logically makes sense, but, according to the drawing Force 3 is negative along the x- and y-axis. Also, when I used Pythagoras (sqrt(rx^2+ry^2) t find the magnitude, I apparently got the wrong answer.
So, how much of this did I get wrong, and what do I do to fix it?
Ohoneo said:
Ax = A cos (theta)
Ay = 33 sin 30 = 17
Dont you think that you identified compononts A opposite? shouldn't Ax = Asinθ and Ay = Acosθ where θ=30degree ?
