How do I simplify log₉(1/27)?
  • Thread starter Thread starter matadorqk
    Logarithms
48 replies · 15K views
matadorqk
#8: Simplify: log91/27
y=logb(x)
x=b^y
I have personally not tried logarithms before, but I think the problem is really easy and I am probably just over-thinking it?
I think that, using the formula's below, 9^a=1/27
So, a=1/243, so my simplified answer should be 9^1/243=1/27..
Can I simplify fractions then, so that 9^1/9=1?
I have personally no exact knowledge on what I am doing, but can someone give me some hints or basic concepts on logarithms? Thanks!
**Edit:
Ok, I might be wrong above, I found some more laws, and since loga (x/y)= logax - loga y,
I get:
log 9 (1) - log 9 (27)
since loga 1 = 0
I know have:
- log 9 (27)
Err.. now what?
I have no idea how to plot it into my calculator...
But from my formulas (first two) I get that 9^2/3=27.. but does simplifying mean turning into exponential form? :S
27 = 3^3 = 9^(3/2) ==> log_9(27) == 3/2
Huh? I'm pretty sure its 2/3... maybe I am wrong but could you further explain yourself?
log(base9) (1/27) = x
9^x = (1/27)
x = log(1/27)/log(9)
9^x = (1/27)
So log (1/27) / log (9)
log (1/27) = - log 27 / log 9
Can I simplify to - log 3 / log (1)
So - log 3 / ..0?
Hmm, so I can't simplify or my answer is undefined...
Is my answer -log 27 / log 9..
Im really lost here.
How about this:
Since log (base a) (a) = 1, does log (base a) (3a) = 3? If so, log (base 9) (27) = 3?
9^x = (1/27) in exponential form ... since it said to simplify, i solved sorry
type in your calculator log(1/27)/log(9) and plug into x, 9^(-1.5) = 1/27
No problem. So, 9^x= 1/27 is simplified?..
*bangs head against wall* ( I knew it wasn't that complicated, :P)
so the general rule, and with the relevant equations you gave should have been enough information for you to solve it
anyways, the way i learned to convert/simplify/solve logs is by how you read logs
log(base) (y) = x
the base must be raised to some power x, to get y
logs are just inverses, one-to-one functions
log(base) (y) = x
Thanks a lot for your help, ill go on to the next log problem :) hehe, I guess it wasn't so complicated, I just really didn't know what they ment by "simplify" but now I will assume that simplifying a log solely involves getting rid of the 'log'. Again, thanks.
i just reviewed logs Monday so it's fresh on my mind!
some can be a real b tho :) have fun
Actually simply means simplify until you cannot simplify anymore. If you can reach a solution that is how far you need to go, like in this case.
Here's how I did it (since you already have the answer :-/):
[tex]log_9(\frac{1}{27}) = \frac{log_{3}\frac{1}{27}}{log_{3}9}[/tex]
[tex]\frac{log_{3}\frac{1}{27}}{log_{3}9} = \frac{log_{3}3^{-3}}{log_{3}3^2}[/tex]
[tex]\frac{log_{3}3^{-3}}{log_{3}3^2} = \frac{-3}{2}[/tex]
[tex]27 = 9 * 3 = 9 * 9^{1/2} = 9^{1 + 1/2} = 9^{3/2}[/tex]
[tex]1/27 = 27^{-1} = (9^{3/2})^{-1} = 9^{-3/2}[/tex]
Wow... Thanks a lot for that! That explains a lot :P
Umm, may I ask how you get from [tex]log_9(\frac{1}{27}) = \frac{log_{3}\frac{1}{27}}{log_{3}9}[/tex]
Is there a formula?
Like...: log(base a) (b) = log (base (square root of a)) (b) / log (base (square root of a)
You kind of make sense, but I want to know how to implement it in any problem..
I hope you don't mind explaining after you solved it...
Is there a formula?
Like...: log(base a) (b) = log (base (square root of a)) (b) / log (base (square root of a)You kind of make sense, but I want to know how to implement it in any problem..
Change of base is what it is, most people don't realize you can change to any base and not just base 10.
[tex]log_{a}b = \frac {log_{n}b}{log_{n}a}[/tex] where n is an integer and is the new base.
Umm, but leaving n as an integer doesn't that give room for n=any integer while a and b don't change? I am going to analyze this and ill get back to you.
change-of-base formula is ... log(b)M=log(a)M/log(a)b where log(a) = log(base10)
let's start off with the Proof
Proof, let x = log(b)M ... in exponential form b^x = M
1) b^x = M
2) take the log(a) of both sides ... log(a)b^x = log(a)M
3) solve for x ... x = log(a)M/log(a)b
4) if x = log(b)M ... (step 3) log(b)M = log(a)M/log(a)b
... log(a) can be anything, it doesn't have to be log(base10)
1) b^x = M
so... if my answer is log(3) 3^-3 / log (3) 3^2 = -3/2...
Can it also be log (5) 3^-3 / log (5) 3^2 = -3/2.. ?
Or does the new base have to be related to the original base? This is what has me confused.. How do you define the new base, and what effect does this have on the other terms of the equation?
This would be because even though even though the numbers may be larger/smaller, the ratio is the same? I hope I am right this time, I think I am getting this logs thing :)
i think so ... lol, but I'm no expert.
Thanks, ill re-check with my teacher tommorow. Anyways, I got stuck again.
Convert [tex]\frac{8}{\log_{5}9}[/tex] to an expression of the form [tex]a\log_{3}b[/tex]
Ok that's the problem.
#1: [tex]y=\log_{a}(x)[/tex]
#2: [tex]x=a^y[/tex]
**Im working on it as you read :) bare with me and I'll give you my attempt hehe
hmm ... let me evaluate, i see that 8 can be re-written as 2^3 & 9 as 3^2 ... still thinking
... kicking my ass! hehe
is this correctly typed in?
Convert: [tex]\log_{5}9}[/tex] to log base 3, using the method discussed in this thread...
meh, I just figure the exponent must be negative if it is to produce a fractional result. So, then the problem just reduces to a matter of manipulating 9 to get 27. taking the square root of 9 yields 3 and cubing 3 yields 27. So, the exponent would need to be -2/3
Great!
So, 2^3 over: [tex]\frac{\log_{3}3^2}{\log_{3}5}?[/tex]
As much as that seems simpler and faster, if I don't learn the method to actually do it for any problem instead of solving 1, I'll have problems with similar probs. And um, I think we solved that one already, its actually -3/2
matadorqk said:
Great!
Sorry, yes. 8 over that. And that's it. So I get 4log_3{5}
Err.. big jump there :P, What do I do when I have a.. three layer fraction?
..nvm.. Lemme figure this out
say a/b/c= ca/b?
[tex]\frac{a}{(\frac{b}{c})} = \frac{ac}{b}[/tex]
but: [tex]\frac{(\frac{a}{b})}{c}=\frac{a}{bc}[/tex]
I used this formula and the one above,
[tex]\log_{a}x^y=y\log_{a}x[/tex]
[tex]\frac{8(\log_{3}5)}{2\log_{3}3}[/tex]
Right?
But then I get
[tex]4\log_{3}\frac{5}{3}[/tex]
Right?
That's right.
But then I get
this is wrong. (log_a{x})/(log_a{y}) is not equal to log_a{x/y}. what is log_3{3}?
That's right.
Ugh right! It equals 1!
So there we have it. [tex]\frac{8}{2}(log_{3}5)[/tex] So: [tex]4\log_{3}5[/tex] Yay!
Improvement!
