How do I solve for x in this equation?
  • Thread starter Thread starter Cuisine123
To solve the equation -x^3 + 6x^2 - 11.998x + 8 = 0, various methods can be employed, including factoring and numerical methods like Newton's method. The equation is cubic, and while it may not have rational roots, the rational root theorem suggests testing integers such as ±1, ±2, ±4, and ±8. The approximate solution x = 2.16 indicates that exact roots may not be rational due to the non-integer coefficient. Ultimately, using a calculator or numerical methods is recommended for finding solutions to cubic equations.
Cuisine123
How can I calculate x in this equation: -x^3+6x^2-11.998x+8 = 0?
**I tried factoring, but how??
**I know that the answer turns out to be x=2.16, but how did this come about?
What course is this from? 2.6 is not an exact answer so maybe they want you to use Newton's method? There are a few ways of solving this-- but the method will depend on what course you are taking.
Hi Cuisine123! :smile:
(try using the X2 tag just above the Reply box :wink:)
It's a cubic, and you wouldn't be expected to know how to solve it in an exam.
(Basically, you put x = y + a so that the equation is of the form y3 + Ay + B = 0, and then use a formula)
Just use a calculator! :wink:
By the "rational root theorem" the only possible roots are \pm 1, \pm 2, \pm 4, and \pm 8. If that "11.998" were "12", then 2 would be triple root. As it is, however, that equation has no rational roots.
There is an analogous formula for polynomials of degree three: The solution of ax3+bx2+cx+d=0 is
danielatha4 said:
The solution of ax3+bx2+cx+d=0 is …
shouldn't there be three solutions? :confused:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
