How Do I Solve Poisson's Equation for V?
  • Thread starter Thread starter leoflindall
2 replies · 2K views
leoflindall
[tex]\nabla[/tex][tex]^{2}[/tex]V=([tex]\rho[/tex])/([tex]\epsilon[/tex][tex]_{0}[/tex])
I have a function of x which i can supstitute into Charge density and boundary conditions, however my problem with this is very simple. How to i manipulate the equation to get a funvtion for V. Obviously i need to get rid of the div of the div of v and i assume this has to be done through some form of intergration?
I assume this isn't as simple as intergrating both sides twice?
I would appreciate any guidance that can be given on this.
Regards.
Leo
In general, differential equations in physics are hard to solve. From what you posted, I understand that the function [itex]\rho = \rho(x)[/itex] is given, and you are working in one dimension only.
In that case,
[tex]\nabla^2 V = \frac{d^2 V}{dx^2}[/tex]
so you can solve your equation (I'm wiping the constant into rho, for notational convenience)
[tex]\frac{d^2 V}{dx^2} = \rho(x)[/tex]
by integrating twice.
For example, when [itex]\rho(x) = \epsilon_0 x^2[/itex] you would simply get
[tex]V''(x) = x^2[/tex]
so
[tex]V'(x) = \frac13 x^3 + c[/tex]
and
[tex]V(x) = \frac{1}{12} x^4 + c x + k[/tex]
The only snag might be that the integration is very hard to do: just pick a nasty function like [tex]\rho / \epsilon_0 = \sqrt{1 + x e^x}[/tex] and your scr*wed :)
Note that once you go to two dimensions, things already get far less trivial, you would have to solve
[tex]\frac{\partial^2V}{\partial x^2} + \frac{\partial^2 V}{\partial y^2} = \rho(x, y)[/tex]
which takes a little more than two integrations (usually, you already need things like symmetry and polar coordinates here to make anything of it).
That makes makes perfect sense! Thank you for your help!
