How Do I Solve These Challenging Integrals?
  • Thread starter Thread starter noblerare
    Integrals
5 replies · 2K views
noblerare
I've been having trouble with the following three integrals. If anybody could give me a hint on how to get started, that would be greatly appreciated.
Problem 1.
[tex]\int[/tex][tex]\frac{dx}{1+cos^2(x)}[/tex]
2. The attempt at a solution
I've tried writing it in these ways:
[tex]\int\frac{dx}{2-sin^2(x)}[/tex]
[tex]\int\frac{dx}{(secx+cosx)(cosx)}[/tex]
Let u=cosx
[tex]\int\frac{-du}{\sqrt{1-u^2}(1+u^2)}[/tex]
So far I've gotten nowhere. I've also tried to make the integral look like the integral for arctanx. I realize that I need to have a -sinx in the numerator but don't know how to make it work out.
Problem 2:
[tex]\int[/tex][tex]\frac{dx}{sec^2(x)+tan^2(x)}[/tex]
I've tried writing it like:
[tex]\int[/tex][tex]\frac{cos^2(x)}{1+sin^2(x)}[/tex]
U-substitution and trig-substition don't seem to work.
Problem 3:
[tex]\int[/tex][tex]\frac{dx}{x^3+1}[/tex]
In this problem I actually got somewhere:
I split the denominator into two polynomials and used partial fractions.
I ended with:
[tex]\frac{1}{3}[/tex]ln(x+1) - [tex]\frac{1}{3}[/tex][tex]\int[/tex][tex]\frac{(x-2)dx}{x^2-x+1}[/tex]
Then:
[tex]\frac{1}{3}[/tex]ln(x+1) - [tex]\frac{1}{6}[/tex][tex]\int[/tex][tex]\frac{(2x-4)dx}{x^2-x+1}[/tex]
[tex]\frac{1}{3}[/tex]ln(x+1) - [tex]\frac{1}{6}[/tex][tex]\int[/tex][tex]\frac{(2x-1)dx}{x^2-x+1}[/tex] - [tex]\int[/tex][tex]\frac{-3dx}{x^2-x+1}[/tex]
[tex]\frac{1}{3}[/tex]ln(x+1) - [tex]\frac{1}{6}[/tex]ln(x^2-x+1)+3[tex]\int[/tex][tex]\frac{dx}{x^2-x+1}[/tex]
Now I'm stuck... don't know what to do.
Any help would be greatly appreciated!
For the first two, trying [tex]t= \tan (x/2)[/tex] should work nicely =]
Third one, for the final integral, complete the square in the bottom and get it into the standard arctan form.
Hey thanks for the help.
For the integral:
I use u=tan(x/2) so, after much simplification, I get...
[tex]\int[/tex][tex]\frac{2(1+u^2)du}{(1+u^2)^2+(1-u^2)^2}[/tex]
[tex]\int[/tex][tex]\frac{(1+u^2)du}{(1+u^4)}[/tex]
Now I don't know exactly what I should do. If I try trig substituion, I end up with..
[tex]\frac{1}{2}[/tex][tex]\int[/tex][tex]\frac{d\theta}{\sqrt{tan\theta}}[/tex] + [tex]\frac{1}{2}[/tex][tex]\int[/tex][tex]\frac{tan\thetad\theta}{2\sqrt{tan\theta}}[/tex]
Now I don't really know what I should do from here...
You should check your simplification, i get [tex]\int \frac{ 2(u^2+1)}{1+ (u^2-1)^2} } du[/tex] which can be done with some more partial fractions.
Hi noblerare! :smile:
Yes, Gib Z's tan(x/2) method is a good one, which you should definitely remember, and it certainly works in this case.
But in this case, the square means that tanx might work even better (or cotx).
Alternatively:
Hint: mutiply both top and bottom by cosec^2(x) … now what does that remind you of … ? :smile:
Yay! I finally got it. Thank you so much, Gib Z and tiny-tim!
