How do I use touchlistener to load new images on my Java Android app?
  • Context: Java
  • Thread starter Thread starter whitehorsey
    Android Java
The forum discussion centers on implementing an OnTouchListener in a Java Android application to load new images based on user interaction. The user initially loads six images representing days of the week, and upon selecting one, they expect to load another set of six images for the months. The provided code snippet correctly sets up the OnTouchListener but fails to execute the image loading logic within the event handler. The solution involves modifying the event handler to call the addImages method, which is responsible for loading the new images.
  • Understanding of Java programming language
  • Familiarity with Android development concepts
  • Knowledge of OnTouchListener and MotionEvent classes
  • Experience with image loading techniques in Android
  • Implement the addImages method to ensure it correctly loads new images
  • Learn about debugging techniques in Android Studio, including setting breakpoints
  • Research Android UI components and their refresh mechanisms, particularly ListView and ImageView
  • Explore event handling in Android to understand how to manage user interactions effectively
Android developers, Java programmers, and anyone interested in enhancing user interaction in mobile applications through touch events.
whitehorsey
On my app there are two rows that holds 3 images each (as seen in the image attachment). In the beginning, the 6 images are loaded and then when a person touches one of the images I want the other 6 images to be loaded. It's a series of choices. Ex. First 6 images would be to pick what day it is. After selecting the day, it would be replace the 6 images with 6 different choices for which month is it.
There is a series of choices in the series there is a list of the six choices that will be loaded.
I'm not sure how to use touchlistener so far I have this:
Code:
if(count > 1)
			imageview.setOnTouchListener(new OnTouchListener()
			    @Override
			    public boolean onTouch(View v, MotionEvent event)
			        if(event.getAction() == MotionEvent.ACTION_UP)
			            count--;
			            return true;
			        return false;
If the there is more than one choice series (cause there will be some parts of the app where there won't be 6 new choices after selecting one), check to see if someone touched an image. However, the app right now loads the other choices from the series (day -> month) without waiting for someone to touch an image. How do I fix this?
Technology news on Phys.org
I know nothing about developing for Android nor in Java, but I know a thing or two about parentheses, and I am not convinced they look OK.
I thought that as well, but later decided they're probably OK. The OnTouchListener parameter
This part --
Code:
			    @Override
			            count--;
			            return true;
			        return false;
-- is an inline definition of the OnTouchListener method that is a parameter. The right brace on the last line matches the left brace at the top of what I copied. The right parenthesis matches the left parenthesis in setOnTouchListener(.
whitehorsey, your explanation of what you're trying to do is unclear.
After the 6 images are loaded and you touch one of the images, is the idea that 6 different images are to be loaded?
For something to happen when you touch one of the images, you need code in your OnTouch event handler to load the 6 new images. In your code, all that happens is that count is decremented.
Yes, it occurred to me that it can work this way, but I am not convinced it is the intent, it looks more like the code was pasted in the wrong place, producing code that is accidentally syntactically correct.
Or at least, in my code I would put parentheses differently, to not leave this "accidental correctness" impression.
But as I wrote, I know nothing about Java. I just started to learn yesterday.
Yep! I'm making a calendar so the first 6 images loaded are some random days of the week (mon, tues, etc.) . The person selects one of the days then it will load 6 random different images these will be to select the month.
Thank You for catching that!
Code:
if(count > 1)
			iv.setOnTouchListener(new OnTouchListener()
			    @Override
			        	count--;
			        	addImages(series.getList().get(index));
			            return true;
			        return false;
addImages passes the new 6 images. I tried touching the icons but nothing is happening.
I/anyone would need to see the addImages method to see how the method passes the images.
If you don't want to post it it's okay, but put breakpoints on the addImages method code and click on the cockroach (or ladybug) of eclipse. Sometimes it happens that whatever control one is using needs an explicit refresh (like ListViews sometimes, depending on how it is being used).
  • · Replies 75 ·
  • · Replies 49 ·
12K
