How Do Jacobi Elliptic Functions Solve Nonlinear Differential Equations?
  • Context: High School
  • Thread starter Thread starter MalachiK
    2nd order Method
The discussion revolves around the application of Jacobi elliptic functions to solve a nonlinear differential equation of the form ##\frac{d^2x(t)}{dt^2} + B(x(t))^3 = 0##. Participants explore methods for finding the function ##x(t)## given initial conditions and the nature of the system.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant presents a nonlinear differential equation and seeks methods to solve for ##x(t)##, noting that the solution is periodic.
  • Another participant provides a derivation involving a substitution and integration, leading to an expression for ##\frac{dx}{dt}##, but expresses uncertainty about its correctness.
  • A different participant suggests that knowing the initial conditions could allow for perturbation methods or a naive expansion to approximate a solution analytically, such as using a truncated Taylor series.
  • A link to Jacobi elliptic functions is shared, indicating a potential method for solving the problem.
Participants do not reach a consensus on the method to solve the equation, and multiple approaches are suggested, including perturbation methods and the use of Jacobi elliptic functions.
The discussion lacks specific details on the initial conditions, which may affect the proposed methods. There are also unresolved mathematical steps in the derivation provided by one participant.
Readers interested in nonlinear differential equations, Jacobi elliptic functions, and methods for solving differential equations in mathematical physics may find this discussion relevant.
MalachiK
I have ##\frac{d^2x(t)}{dt^2} + B(x(t))^3 = 0## for a system where I know the initial conditions and where B is a constant that's constructed from the properties of the system. I would like to find ##x(t)##.
I've modeled the system in Python and produced some graphs. I know that ##x(t)## is some periodic function.
Could somebody name the method that I should study so that I can get a solution?
After some further reading I've got this...
Let ##s = x'## so ##s' = x''##
##-Bx^3 = x'' = s' \frac{ds}{dt} = \frac{ds}{dx}\frac{dx}{dt} = \frac{ds}{dx} s##
##-\int{Bx^3 dx} = \int{s ds} ##
##\frac{-Bx^4}{4} + C = \frac{s^2}{2}##
2C is just a constant that I'll rename C
##\sqrt{C-\frac{Bx^4}{2}} = s = \frac{dx}{dt}##
Since ##x(0) = x_0## and ##x'(0) = 0## we have ##C-\frac{Bx_0^4}{2} = 0## so ##C = \frac{Bx_0^4}{2}##
##\frac{dx}{dt} = \sqrt{\frac{B}{2}}\sqrt{x_0^4-x^4}##
##\sqrt{\frac{B}{2}}\int{\frac{1}{\sqrt{x_0^4-x^4}}dx} = \int{dt}##
I don't know if this is correct, but it seems plausible. Now to evaluate the integral.
Could you state the initial conditions? I ask because you may be able to perturb the equation, take a naive expansion, and approximating your solution analytically. It would not be exact but the method can be incredibly close (like a truncated Taylor series).
  • · Replies 0 ·
