What is luminosity and how does it affect particle collisions?
  • Thread starter Thread starter nesp
    Particles
Luminosity in particle accelerators is crucial for determining the probability of collisions between particles, such as protons. It is defined as the number of particles per unit area per unit time multiplied by the opacity of the target, indicating the likelihood of interactions. In practice, not all particles collide, which is beneficial for managing the aftermath of collisions. The Tevatron's Run II faced challenges due to insufficient luminosity, impacting Higgs boson detection, but advancements in electron cooling techniques have improved this issue. Understanding luminosity is essential for optimizing collision rates in particle physics experiments.
nesp
In a particle accelerator where, say, protons are accelerated in opposite directions and made to collide, how are the particles brought close enough to actually collide? Protons are extremely small, and their mutual positive charges repel. How does the collider manage to target protons so precisely that they collide?
They don't. Rather they rely on the fact that there is a finite probability that a collision will take place -- think of beam density as an unnormalized probability distribution. I'm far from expert in this topic, but I suspect making the probability of collisions as high as is practically possible is a major design concern.
Regards,
Reilly Atkinson
Simply put, they have lot and lots of photons in each bunch. Most of them miss (which is actually good because if they all hit it would take a while to clean up the mess).
There is something in beam physics called the "luminosity". It is roughly defined as the number of particles per unit area per unit time times the opacity of the target or colliding particle, usually expressed in either the cgs units cm-2 s-1 or b-1 s-1. The integrated luminosity is the integral of the luminosity with respect to time. What this number tells you is roughly the probability of collision between the particle.
This was the main problem of Run II of the Tevatron a while ago - they didn't have the expected luminosity that was needed if they were to have any chance of detecting a Higgs boson. That problem right now appears to have been solved with the help of a better electron cooling technique on the proton beams.
Zz.
  • · Replies 17 ·
  • · Replies 43 ·
