How Do SI Units Affect Calculations in Fluid Statics?
6 replies · 1K views
clueless8
I'm having trouble getting the correct answer on two problems within one and I don't know where I'm going wrong. I will go to my T.As during the week but I would rather finish my homework this weekend.
The question is If you were to dive down 12.5m below surface level, what is
1. The pressure due to water alone?
2.The total or absolute pressure at depth given atmospheric pressure = 1.01E5 N/m^2
P = hpg
Ptotal = Pgauge + Patm
For A) I used P = hpg (h=0.0125km, p=1000kg/m^3, and g= 9.8m/s^2) this gave me 122.5N/m^2
For B) I used Ptotal = Pgauge + Patm
= 1.01E5 + 122.5 = 101122.5 N/m^2
clueless8 said:
Homework Statement: I'm having trouble getting the correct answer on two problems within one and I don't know where I'm going wrong. I will go to my T.As during the week but I would rather finish my homework this weekend.
Relevant Equations: P = hpg
Why did you convert to km?
Reply
Welcome!
1 Pascal = Force of 1 Newton per square meter
Atmospheric pressure at sea level = 101,325 Pascals = 760 mm Hg = 760 torr = 14.7 psi = 1 atm
Reply
I have trouble in this area, I assumed I had to due because the final answer asks for N/m^2 so I thought it had to be in km due to SI units , should I stick with 12.5m ?
The SI base unit of length is 1 m, not 1 km. The derived unit of newton is 1 N = 1 kg m/s2, not a km to be seen anywhere. The only ”k” in there is in kg, the SI base unit for mass.
