How do we use dynamic programming?
15 replies · 3K views · last reply
evinda
MHB
Hello! (Wave)
Could you explain to me how we can use dynamic programming in order to solve a non linear programming problem?
What do we do for example if we are given the following problem?
$$\max (y_1^3-11 y_1^2+40 y_1+y_2^3-8y_2^2+21 y_2) \\ y_1+y_2 \leq 5.4 \\ y_1, y_2 \geq 0$$
If this is not possible, how else could we solve the problem using a method that is related to optimization?
evinda said:
Hello! (Wave)
Hey evinda! (Smile)
We can't do it with linear programming (the Simplex method), since it's not linear.
But there are many non-linear methods like:
- Graphing it, which is doable since there are only 2 dimensions,
- GRC non-linear, which is what Excel does
- Lagrange multipliers
- Powell's conjugate direction method
I like Serena said:
Hey evinda! (Smile)
We have done Lagrange multipliers in class... (Yes)
But how can we apply them in this case? (Thinking)
There are 4 cases:
  1. The objective function takes its maximum strictly inside the feasible region.
  2. The maximum is where $y_1+y_2=5.4$.
  3. The maximum is where $y_1=0$.
  4. The maximum is where $y_2=0$.
If we assume that $y_1+y_2\le 5.4$ is a binding constraint (case 2), then we have:
$$\Lambda =(y_1^3-11 y_1^2+40 y_1+y_2^3-8y_2^2+21 y_2) + \lambda(y_1+y_2 - 5.4)$$
Solve for each of the derivatives being zero... (Thinking)
I like Serena said:
There are 4 cases:
So do we have to check all of the cases to solve the problem? (Thinking)
So now we check Case 1? Could you explain to me why we define $\Lambda$ like that?
You mean that we solve $\frac{\partial{\Lambda}}{\partial{y_1}}(y)=0$ and $\frac{\partial{\Lambda}}{\partial{y_2}}(y)=0$ ? (Thinking)
From a graph, we can immediately see which case applies.
Otherwise, yes, we would have to check all cases.
My example was to check case 2.
That's just how I've learned Lagrange multipliers. How would you do it? (Wondering)
For case 1, that's indeed what we need to solve (where $\Lambda$ is without the $\lambda$ part).
For case 2 we need additionally that $\frac{\partial{\Lambda}}{\partial{\lambda}}(y_1, y_2; \lambda)=0$. (Nerd)
How can we make the graph? For $y_1=0$ the function gets for example $y_2^3-8y_2^2+21 y_2$... (Sweating)
What does $\frac{\partial{\Lambda}}{\partial{\lambda}}(y_1, y_2; \lambda)$ represent? Do we consider $\lambda$ to be a constant? (Thinking)
Take a look at this contour plot on Wolfram.
Which clue can we get from it? (Wondering)
No, $\lambda$ is a dummy variable.
If we have a problem of the form $\max f(\mathbf x)$ where $g(\mathbf x)=0$ and $h(\mathbf x)=0$, we can apply the Lagrange multipliers method.
That means that we first define:
$$\Lambda(\mathbf x; \lambda, \mu) = f(\mathbf x) + \lambda g(\mathbf x) + \mu h(\mathbf x)$$
and then solve:
$$\pd \Lambda {x_1} = 0 \\
\vdots \\
\pd \Lambda {x_n} = 0 \\
\pd \Lambda \lambda = 0 \\
\pd \Lambda \mu = 0
and then solve:
\vdots \\
\pd \Lambda \mu = 0
In this case do we pick $h(x) \equiv 0$ ?
We have $\frac{\partial{\Lambda}}{\partial{y_1}}=3y_1^2-22y_1+40+ \lambda \\ \frac{\partial{\Lambda}}{\partial{y_2}}=3y_2^2-16y_2+21+ \lambda $
Right?
For instance, or we just leave the whole $h(\mathbf x)$ and $\mu$ part out. (Nerd)
Right?
And additionally $\pd \Lambda \lambda = y_1+y_2-5.4$.
Hey! That simply is the constraint! (Happy)
Oh yes... And what do we get from that? (Thinking)
That we need to solve the system:
\begin{cases}3y_1^2-22y_1+40+\lambda &= 0 \\
3y_2^2-16y_2+21+\lambda &= 0\\
y_1+y_2-5.4 &= 0
\end{cases}
That is, 3 equations with 3 unknowns.
Btw, we're not really interested in $\lambda$ itself, so it makes sense to eliminate $\lambda$ first. (Mmm)
y_1+y_2-5.4 &= 0
\end{cases}
Then we get $y_1=3.2$ and $y_2=2.2$. Or am I wrong? (Thinking)
That is correct. (Nod)
Then the function is equal to $66.256$, right?
So now do we check the other cases?
