How Do You Calculate Maximum Displacement and Speed in a Standing Wave?
  • Thread starter Thread starter xsc614
    String Wave
To calculate maximum displacement and speed in a standing wave described by the function y(x, t) = 0.022 sin 4πx cos 54πt, the maximum displacement occurs when the cosine term equals one, typically at t=0. For the specified positions (x=0.1m, 0.25m, 0.3m, 0.5m), the maximum displacement was calculated but yielded incorrect results, possibly due to significant figure issues in the Webassign system. The maximum displacement was found to be 0.021 m at x=0.1m, while it was 0 at x=0.25m and x=0.5m. To find maximum speed, one must differentiate the wave function with respect to time, but the method for calculating velocity from the position function was unclear to some participants. Accurate calculations and attention to significant figures are crucial for successful submissions in online platforms.
xsc614
The wave function for a standing wave on a string is described by y(x, t) = 0.022 sin 4πx cos 54πt, where y and x are in meters and t is in seconds. Determine the maximum displacement and maximum speed of a point on the string at the following positions.
Find Ymax and Vmax at these points on the string.
An(x)=Ansinknx (Amplitude of a string vibrating in its nth node)
Wave equation for a standing wave in the nth harmonic motion: yn(x,t) = Ansin(knx)cos(wnt+δn)
Kind of unsure on the equations for this problem.
I assumed the maximum displacement would occur at t=0 when the cosine part of the equation equalled one. I plugged in the x values for the different points and solved for y, but did not get the correct answer. Read the entire chapter of the book and it is pretty vague and gives no example problems on calculating max displacement and max velocity like this
What you explained makes sense to me... can you show your work including the numbers?
y(x, t) = 0.022 sin 4πx (1)
y(x, t) = 0.022 sin (4π(.1m)) (1)
y(x, t) = .021 m
Answer came back as incorrect. That π character is pi if you can't tell.
Update: I used this method for all other points of (x) and got the right answers. Maybe webassign is just not accepting the right amount of sig figs or something...
I got 0 for x=0.25m and 0.5m for max displacement, so the velo's were 0 m/s... but since cos(54pi*t) =1, how do you solve for t to get the velocities for the other values of x?
From what I've heard, Webassign checks to see if you're within a certain percentage of the right answer, but it shouldn't mark you incorrect for having the wrong number of significant figures. You could try putting in one more decimal place and see if it helps.
For the velocity part of it: you have an equation for position. In general, when you have the position, how do you find velocity from it?
