How Do You Calculate Predicted Values in Least Squares Regression?
The discussion revolves around calculating predicted values in a least squares regression model, specifically focusing on the relationship between the response variable Y and the predictor variable X. Participants are tasked with finding the predicted value at the average of the predictor variable, denoted as y(hat)(Xbar).
  • Participants discuss the formulation of the least squares estimates for the intercept and slope, and how to express the predicted value in terms of these estimates. There are questions about the correct notation and whether the predicted value at Xbar equals the average of Y.
Several participants have offered insights into the algebraic manipulation required to express y(hat)(Xbar) in terms of the averages and the estimates. There is an ongoing exploration of notation and the implications of the relationships between the variables, with some participants affirming the correctness of expressions derived from their discussions.
Participants express uncertainty about notation and the assumptions underlying the relationships in the regression model. There is a focus on ensuring clarity in mathematical expressions and the conditions under which certain equalities hold true.
stats_student
note a linear regression model with the response variable Y=(Y1..Yn) on a predictor variable X=(X1..Xn). the least squares estimates of the intercept and slope a(hat) and B(hat) are the values that minimize the function: (see attached image)
and the problem reads on further -
further predicted values equal y(hat)(x)=a(hat)+b(hat)x (note y(hat) is meant to be read as a function of x)
i have been asked to find y(hat)(Xbar), where X(bar) is the average of the Xi's. (note y(hat) is meant to be read as a function of Xbar).
i'm not sure where to start with this question. advice as to whether I'm on the right track is all i need for now.
so i was thinking that i could use the fact that
a(hat) = Y(bar)-B(hat)X(bar) and B(hat) = (sum) (Xi-X(bar))(Yi-Y(bar)) /(sum) (Xi-X(bar))^2
but I'm not exactly sure how to solve for y(hat)X(bar) -(yhat as a function of Xbar)
should i be trying to get a equation with only a(hat) , b(hat) , and Xbar?Thanks for the help - apologies for poor notation
If you have set up and solved the least-squares equations (so that you know the parameters ##\hat{a}, \hat{b}## in terms of the ##\{x_i, y_i\}##, you can just substitute ##x = \bar{x}## into the equation ##\hat{y} = \hat{a} + \hat{b} x##, and carry out algebraic simplification.
BTW: it is easy to employ good notation---just use LaTeX. To see how I did it, just right-click on an expression and to to the menu item to 'display math as tex commands'. This site has a brief LaTeX tutorial on the use of LaTeX, but I cannot say exactly where/how to find it; others may know.
so if i do this should i get
\hat{y} =Y(bar)?
y(hat)(Xbar) = Y(bar)? still hopeless at notation :(
or should i get,
Y(bar) = a(hat) +b(hat)X(bar)
stats_student said:
or should i get,
You need to tell the system "LateX starts here" ... and "Latex ends here", with your mathematical expressions in between.
For displayed equations use
[t ex] ...your expressions ... [/t ex]
with no spaces between the 't' and the 'ex', and not in a red-colored font (which I used just for emphasis). Doing that on your expression above gives
[tex]\bar{Y} = \hat{a} + \hat{b} \bar{x}[/tex]
Note that we write \bar{Y}, not Y(bar), and we write \hat{a}, not a(hat). Some people prefer the look of \overline{...} instead of \bar{...}, and using that instead gives
[tex]\overline{Y} = \hat{a} + \hat{b} \overline{x}[/tex]
For in-line equations or expressions, use
# # ... expression... # #
with no space between the two #s at the start and at the end, and not in a red font. Doing that with your expression above gives ##\bar{Y} = \hat{a} + \hat{b} \bar{x}##, as wanted.
Anyway, you cannot just wrote that ##\bar{Y} = \hat{a} + \hat{b} \bar{x}##, because the right-hand-side is ##Y_{\text{fitted}}(\bar{x})##, but how do you know that ##Y_{\text{fitted}}(\bar{x}) = \bar{Y}##? Can you even be sure it is true?
should i get y(Xbar) = a(hat)+b(hat)X(bar)
Yes, but that is not the end of the story. You ought to be able to simplify it a lot, using either the explicit expressions for ##\hat{a}## and ##\hat{b}##, or by exploiting the fact that ##\hat{a}, \hat{b}## satisfy some particular equations obtained by minimization of the total squared error.
ahhh... so after doing some algebra i get yhat(Xbar) = Y(bar)
let me try in notation [tex]\hat{y}(\bar{x})=\bar{Y}[/tex]
Yes, exactly.
