How Do You Calculate Radius in Uniform Circular Motion?
  • Thread starter Thread starter george256
6 replies · 2K views
george256
A 2.4 kg object attached to a horizontal string moves with constant speed in a circle of radius R on a frictionless horizontal surface. The kinetic energy of the object is 75 J and the tension in the string is 330 N. Find R.
well i keep thinking i have my mass i know gravity so i should multiply those to get mg then i feel like i should multiply mg with my 330N because that is my tensional force, and i have no clue what to do with the 75 j. Am I going in the right direction though?
i can get my velocity from k but with that what do i do?
I figured it out thank you so much for the help. I had one of those duh moments when i realized. I will write down what I did so you can tell me if it was the correct and simplest way to go about it if you do not mind. first off i found my velocity using k=1//2mv^2 then i used my force of 330N in f=ma and got my a then i used the circular motion equation a=v^2/r and that was my answer. Does that seem like the correct way to do it?
Looks good !
