How Do You Calculate the Specific Heat of a Nitrogen Molecule at 13.6K?
To calculate the specific heat of a nitrogen molecule at 13.6K, the relevant equation involves constants like R, h, and k, but requires the frequency (v) of the molecule for completion. The participant is uncertain about how to determine this frequency and whether their approach is correct. Historical formulas for molar specific heat, such as those proposed by Bryant in 1934, provide coefficients for nitrogen but may not directly apply to this quantum context. The discussion also highlights the need to divide by Avogadro's number to find the specific heat per molecule, which complicates the calculations. Overall, the thread emphasizes the challenges of applying thermodynamic principles in a quantum physics framework.
Finaid
Estimate the precise value for the specific heat of a nitrogen molecule at T=13.6K
I'm pretty sure the correct equation is:
Cp = (7/2)*R + R((hv)/(kT))2 *((e(hv/kT))/(e(hv/kT)-1)2
So R=8.314 J K-1mol-1
T=13.6K
h=6.626*10-34m2kg s-1
k=2pi/λ
v= ?
Well, I know that diatomic molecules oscillate at a single characteristic frequency,v, but I'm not sure how to find what frequency that is and without it I can't finish the equation. I figure if I had the frequency, I could find λ or vice versa but I need both to finish the problem. Or am I approaching this in too straightforward a manner?
Any help or confirmation that I'm at least headed in the right direction would be appreciated.
Such equations are always approximate and of questionable value to physicists, chemists and engineers from a practical view.
Bryant in 1934 came up with a formula for molar specific heat at constant pressure:
cp = a + bT + cT2
For N2 he gave
a = 6.30 cal/mole-K
b = 1.819e-3 cal/mole-K
c = -0.345e-6 cal/mole-K.
It depends on what stage of thermodynamics you're at. Modern expressions have indeed increased the accuracy of this parameter. Afraid I'm not knowledgeable about them.
Of course, to get the specific heat of a single molecule you have to divide by Avogadro's number.
Well, I'm a 3rd year Physics Undergrad and this is a question for my Quantum Physics class, not Thermodynamics. I think that's why I have to use the equation above and in the derivation I have for that, Avogadro's number cancels out somewhere along the way. There's a section in my lecture notes deriving this equation for specific heat of a diatomic molecule, but no examples or mention of how to find v.
Thanks for giving it a go anyway!
Could I put the frequency v=c/λ? I don't know whether I'm able to assume the conditions for a vacuum, but it would cancel out λ, the wavelength and then ((e(hv/kT))/(e(hv/kT)-1) would go to zero, which would leave Cp=7R/2. This doesn't seem right but it's more than I had yesterday.
You're in PH356, yeah?
Yes, sadly.
