How Do You Calculate Thrust and Pressure in Fluid Dynamics and Aeronautics?
The discussion focuses on calculating thrust and pressure in fluid dynamics using a water tank and a model helicopter as examples. For the water tank, the thrust on the base and sides is derived from the weight of the water and the area of contact, with pressure varying based on depth. The helicopter's thrust is calculated by considering its mass, acceleration, and the forces acting on it during ascent. Participants clarify that pressure is not constant across the tank's sides due to varying depths and emphasize the importance of using correct equations for thrust calculations. The conversation also touches on the relationship between Young's modulus and density, concluding that they are not directly related.
jigoku_snow
1)a water tank has a rectangle base of area 5m x 4 m and is 3 m deep. if it is full of water, calculate the thrust on the base and on each side.
2)a model helicopter of mass 5 kg rises with constant acceleration from rest to a height of 60 m in 10 s. find the thrust exerted by the rotor blades during the ascent.
1)density= mass/ volume
pressure = force / area
2) s= (u+v)/t
v= ut + 1/2 at^2
1) weight of water when it is full = 1000 x (3 x4 x 5) = 60000 x 10 = 600000N
upthrust = P= F/A
on sides = 600000/12 = 50000N
base= 600000/ 20 = 30000 N [ ans : 5.9 x 10 ^5, 1.8 x 10 ^5, 2.2 x 10^5 N]
2) thrust force - weight = ma
60=v/2 (10)^2
v= 12 m/s
12= 1/2 (10)^2 a
a= 0.24 m/s^2
thrust force = 5 x 0.24 + 50 = 51.2 N [ans: 55]
upthrust = P= F/A
The 'thrust' is the total force on each side, not the pressure. Hint: Be careful when calculating the force on the sides, since the pressure is not constant.
Good.
60=v/2 (10)^2
That equation should be: d = ½at²; use it to solve for the acceleration directly.
P=F/A
P acting on the base (y) = h rho g = 3 x 1000 x 9.81 = 29500 Pa
F= 29500 x 20 = 5.9 x 10 ^5 N
F acting on the sides (x) = 5 x 1000 x 9.81 x 12 = 5.9 x 10 ^5N
F on (z) = 4 x 1000 x 9.81 x 15 = 5.9 x 10 ^5 N
* why is my upthrust force is different from the answer given?
* out of topic ( i just learned it today)
- is there any relationship between young's modulus with density?
jigoku_snow said:
P=F/A
This is correct. You calculated the pressure on the bottom, which is uniform. Then used that to calculate the total force.
Not sure what those calculations are doing. What's the average pressure on each side? What's the area of each side?
Not that I know of.
"a water tank has a rectangle base of area 5m x 4 m and is 3 m deep"
let the length = 5m
width = 4 m
height = 3 m
F acting on (x) = F that acting on the sides (left / right)
F acting on Z= F acting on the wall behind/ front
let the length = 5m
width = 4 m
height = 3 m
I understand the problem. So answer my questions.
arent the pressure is equal on all sides?
the area in the bottom = 5 x 4 = 20 m^2
sides= 3 x 4 = 12 m^2
front= 3 x 5 = 15 m^2
No. Pressure depends on depth below the surface.
