How Do You Calculate Width in a Changing Rectangle with Constant Area?
The problem involves a rectangle with a constant area of 200 square meters, where the length is increasing and the width is decreasing. Participants are exploring how to find the width given the rates of change of length and width.
  • Mixed
  • Participants discuss the relationship between length, width, and area, questioning how to derive the width from the given rates of change. Some express confusion about the application of the product rule in differentiation and the implications of a constant area.
There are multiple lines of reasoning being explored, with some participants offering equations based on the relationships between length, width, and area. Guidance has been provided regarding the need to apply the product rule correctly, though no consensus has been reached on the best approach to find the width.
Participants are grappling with the concept of related rates and the differentiation of a constant area, which is central to the problem. There is an acknowledgment of the complexity involved in applying the product rule correctly.
NewsboysGurl91
1. A rectangle has a constant area of 200 square meters and its length L is increasing at the rate of 4 meters per second. Find the width W at the instant the width is decreasing at the rate of 0.5 meters per second.
2. Know: dL/dt= 4 m/s, dW/dt=.5 m/s Want: W
3. LW=A. Then DL/dt * DW/dt = 200 m^2. How do you get W from this?
I have some other questions too. Related rates are hard.
dL/dt*dw/dt= 200 can't possibly be correct, can it? 4*0.5 is not 200! Recheck your differentiation- particularly the "product rule"! Also, it is the area that is the constant 200, not the rate of change. What is the derivative of a constant?
Never mind, I totally forgot about the product rule.
Okay, I got stuck again.
DL/dt*W+ L*DW/dt = 0.
4*W + L* -.5 = 0. How do you find L? Once you find L, isn't it obvious what W will be? Then you wouldn't have to go through this whole rate problem.
use the two equations
solve the original area equation and differential equation simultaneously
That is,
A = wl
0 = 4w - .5l
solve the above for w.
Kay, thanks.
