How Do You Compute Power Cross-Spectral Density for Coherence Functions?
  • Thread starter Thread starter MartinDU
    Density Power
5 replies · 4K views · last reply
MartinDU
Hi all,
I am curently working with frequency response functions on the basis of 1 input data sample and 1 output data sample. As I would like to plot the coherence function, I need to compute the cross-spectral densities. Since I am new to this field, I would like to ask some of you experts whether it is correct to compute a power cross-spectral density (pcsd) as
pcsd_xy = psd_xx.*conj(psd_yy)
where psd = power spectral density.
Is this a correct approach to obtain the cross-spectral density?
Kind regards,
Martin.
No, that's not going to do it. Look at the definition of the cross-power PSD from the Wiener-Khinchin theorem
[tex]S_{xy}(\omega)=\int_{-\infty}^{\infty}{R_{xy}(\tau)e^{-i\omega \tau} d\tau},[/tex]where R is the cross-correlation function
[tex]R_{xy}(\tau)=\int_{-\infty}^{\infty}{x(t) y^*(t+\tau)dt}.[/tex]You can see that you can't get the above from what you wrote (note that your PSD S_xx is found by setting x=y).
Thanks for the answer. Then I have probably made an error on an earlier state since I obtain compliance between the frequency response function when I use
S_xx(w)=|H(w)|^2 S_ff(w)
and
S_xx(w)=H(jw)S_xf(w).
I have posted a small MATLAB script in which I compute these quantities. I know it is a lot to ask for but can you spot something wrong with my computation of the PSDs?
% Time increment %
dt=t(2)-t(1);
% Number of samples %
N=2^nextpow2(length(t));
% Frequency band %
f=1/dt/N*(0:(N-2)/2);
% --- Fast Fourier transformation --- %
% Input data %
Ft_in=fft(wdata_in,N);
% Output data %
xt_out=fft(wdata_out,N);
% --- Power spectral densities --- %
% Power spectral density of input data %
PSD_in=Ft_in.*conj(Ft_in)/N;
% Power spectral density of output data %
PSD_out=xt_out.*conj(xt_out)/N;
% Power cross-spectral densities of input and output data %
PCSD_in_out=Ft_in.*conj(xt_out)/N;
PCSD_out_in=xt_out.*conj(Ft_in)/N;
% Frequency response function %
H=PSD_out(1:N/2)./PCSD_out_in(1:N/2);
Your answer would be highly appreciated.
Thanks in advance and kind regards,
//Martin.
Your input and output PSD's are correct, your cross power calculation is not. You are getting a pleasing result because cross-power would be the wrong thing to use, were you to calculate it correctly. The transfer function is [tex]H(\omega)=\frac{Y(\omega)}{X(\omega)},[/tex] where Y and X are the output and input spectra of your system. Look at your code--you in fact calculate H*, albeit through a very convoluted process.
Again, thank you very much for the answer.
The reason why I want to use the cross-power is that I want informations about the phase angle as well as the magnitude.
So what you are saying is that I through
actually get the complex conjugate of H?
Take a look at your own code:
What does it look like to you?
