How do you compute trig ratios for angles greater than 90 degrees?
  • Level: Undergrad
  • Thread starter Thread starter pokemonDoom
    Elementary Trig
8 replies · 4K views
pokemonDoom
Say I have an acute angle A in standard position in the first quadrant with a rotating arm of length r , terminating at coordinate P(a,b) . Now say I rotate it 90 degrees further from that position to the second quadrant , this ends up at coordinate Q(-a,b) . I draw perpendiculars from those two positions to the x-axis .
for the first triangle , sin A = b/r and cos A = a/r
as for the second triangle , why is sin (90+A) = a/r = cos A
and why is cos(90+A) = -b/r = -sin A
Im confused ... how can you compute the trig ratio for an angle greater than 90 degress ? Why not take the ratio for the acute angle (180 - (90+a))
Pls Help .
Mathematics news on Phys.org
Welcome to PF!
Hi ! Welcome to PF! :smile:
No … (-a,b) is the reflection of (a,b) in the y-axis.
You want Q(b,-a).
Then everythihng will make sense! :smile:
hmm ... but that doesn't solve my problem ... I need to know why the so called "reference angle" or the "corresponding acute angle" actually works for angles greater than 90 degrees , when taking sines and cosines or tangents . Is there a geometric argument for it ?
Im not entirely sure what your question is; but if it boils down to "why is cos(x)=sin(x+90) ?", then you can answer this by looking at the graphs of the sine and cosine functions.
Heres my problem ...
For the triangle in the second quadrant , why does my book state
sin(90+theta) = a/r and cos(90+theta) = -b/r
when clearly (90+theta) isn't even one of the angles in the triangle ... ? This was what I meant when I said why not calculate (180-90-theta) ...
I don't get this part ... ! I've looked up 2/3 trig books by native authors (I live in Nepal) and they don't seem to explain why this is so ... and I have yet to find a good trig book on the internet ... Thanks a mil .
Hi pokemonDoom! :smile:
pokemonDoom said:
For the triangle in the second quadrant …
No … the triangle is not in the second quadrant … its base is still in the first quadrant, and its tip is in the second quadrant.
For an easy example, consider the two triangles OAB and OAC, where O = (0,0), A = (1,0), B = (1,1), and C = (-1,1). So OA = 1, and OB = OC = √2. Put D = (-1,0).
Then angle AOB = 45º, and angle AOC = 135º.
And cosAOB = OA/OB = 1/√2, cosAOC = AD/OC = -1/√2.
But sinAOB = AB/OB = 1/√2, sinAOC = DC/OC = 1/√2. :smile:
Hello Tim ,
Im confused ...
how can the cosine of <AOC be AD/OC ... if I know better , its probably a typo .
and in triangle-DOC (which lies squarely on the second quadrant of my graph) how is it that the sine of <AOC is equivalent to the sine of <DOC ... This is the question in the first place .
Many thanks .
pokemonDoom said:
Im confused ...
Yes … sorry … it should be cosAOC = OD/OC = -1/√2. :redface:
Because sin = opposite/hypotenuse.
The side opposite angle AOB is AB, and the side opposite angle AOC is DC.
And AB = DC, so sinAOB = sinAOC. :smile:
(and of course, the diagram works for any angle, not just 45º)
... I get it !
But isn't the angle opposite side DC <DOC ... ? I am not trying to sound dumb but what youre trying to say is exactly what the question is .
Why should sineAOC =CD/OC , when its perfectly legible that sineDOC = CD/OC .
In essence what youre trying to say is for any angle greater than 90 degrees , the ratio of that angle is equal to the ratio of the acute angle formed with the nearest x-axis ... ?? but why? is there a geometric proof of some kind ?? instead of just guessing that the ratios are equal ?
