How do you derive $x = ihbar d/dp$? Why does this equation hold true?
2 replies · 2K views
Danielk010
TL;DR
I am trying to study for an upcoming exam, and one of the topics is about the relation between position and momentum in qm. I want to understand why the equation holds true and the proof for the equation.
The equation comes from the solution of a homework equation we were given from A Modern Approach to Quantum Mechanics: 2nd edition by Townsend:
\textbf{Show}
\langle p | \hat{x} | \psi \rangle = i \hbar \frac{\partial}{\partial p} \langle p | \psi \rangle
and
\langle \varphi | \hat{x} | \psi \rangle
= \int dp \, \langle p | \varphi \rangle^* \, i \hbar \frac{\partial}{\partial p} \langle p | \psi \rangle
The solution just states that we observe the above equation. Is there a proof someone can show or an explanation on why this formula holds true?
Hi, thank you response. This is from an homework problem, in which the TA for my class has already provided us the solution. They don't explain how:
$$xe^{\frac{-ipx}{\hbar}} = i\hbar \frac{d}{dp} e^{\frac{-ipx}{\hbar}}$$
If I insert the completion relation of the eigenbasis of x (assuming this is what you mean as the completion relation)
$$\int_{-\infty}^{\infty} \psi(x) |x\rangle \,dx$$
then I would just get this (I think):
$$x\int_{-\infty}^{\infty} \psi(x) |x\rangle \,dx$$
Is this the correct way to prove the first equation or the equation below?
$$x = i\hbar \frac{d}{dp}$$​
When you say completion relation of the eigenbasis of x, do you mean the commutator relation between momentum and positon?
