How Do You Find the Molecular Formula for a Compound with a Given Molar Mass?
  • Thread starter Thread starter PrudensOptimus
    Chem Rules
The discussion revolves around finding the molecular formula for a compound given its molar mass, specifically focusing on the compound NO3 and a stated molar mass of 324.06. Participants explore the relationships between empirical and molecular formulas, as well as the implications of changing subscripts in chemical formulas.
  • Some participants propose a method for calculating the molecular formula based on the molar mass and atomic weights of nitrogen and oxygen.
  • Others express confusion regarding the calculations, particularly the relationship between the empirical formula and the molecular formula.
  • A participant argues that the original question is flawed, stating that a compound cannot have a different molecular formula if it has the same chemical identity.
  • Some participants suggest that the approach taken by others is overly complicated and could be simplified by directly calculating the molar mass of the empirical formula.
  • There is a mention of the existence of certain compounds, like C3H8, and the non-existence of others, like C6H16, to illustrate the importance of chemical relevance in formulas.
  • One participant notes their ongoing learning in chemistry, indicating a lack of familiarity with some of the concepts discussed.
  • Another participant introduces a formula for alkanes, but its relevance to the original compound NO3 is questioned.
Participants express differing views on the validity of the calculations and the implications of changing subscripts in chemical formulas. There is no consensus on the correct approach to the problem, and confusion persists regarding the relationship between empirical and molecular formulas.
Participants highlight limitations in understanding the chemical relevance of certain formulas and the implications of mathematical manipulations in chemistry. The discussion reflects a mix of foundational knowledge and advanced concepts, with some participants still learning the basics.
PrudensOptimus
Math Rules Chem:)
[tex]NO_3[/tex]
What is the molecular formula of this compound if molar mass is 324.06.
Math begins:
[tex]aN + bO = 324.06[/tex]
[tex]N=14, O = 16[/tex]
[tex]14a + 16b = 324.06[/tex]
[tex]N = O/3, O = 3N, a = b/3, b = 3a[/tex]
[tex]a = 162.03/32 =~ 5, b =~ 15.[/tex]
[tex]N_{5}O_{15}[/tex]
Chemistry news on Phys.org
If N=14 and and N=O/3, then 14=O/3 so O=14/3=4.66666... but you say O=16. I think I'm confused.
How old are you?
Is there a point to this thread?
How old are you?
What, did I say something wrong?
Oh. Now I see. 14 and 16 are the amu of them. I didn't look at it.
Originally posted by PrudensOptimus
[tex]NO_3[/tex]
Math begins:
Your work is wrong. The question has no answer. First it TELLS you the formula then it asks for a formula OF THE SAME COMPOUND but with a different mass.
Anybody who knows anything about chemistry will tell you that the same compound will have the same formula. You can't just multiply each of the subscripts by a common factor to get a new formula for "the same compound", it doesn't work like that. OH and H2O2 are NOT the same. They don't have the same name, properties, or even charge. Let's look at another formula; C3H8. If we multiply the subscripts by 2 we get C6H16. The problem is that C6H16 doesn't even exist; it has too many hydrogens.
You can't just multiply the subscripts by a common factor like that.
ShawnD: I think you need to look into the context of this particular question. The first line is the empirical formulae, which is essentially just the ratios of atoms in each molecule of the compound. The answer PO derived is correct.
Though IMHO, he dragged it out much more than he should have. The simplest way is just to calculate molar mass for the empirical formula, divide this from your given real mass, and multiple each subscript by the result of the above.
I should write a research paper on this :) Using real math to solve chemistry.
Too bad your math does not take into the equation the chemical relevancy of the answer.
As Shawn said, C3H8 exists, but C6H16 (everything times 2) does not.
I don't know what you are talking about because I'm still teaching myself chemistry... and probably some advance stuff u were mentioning.
Anyways, like every other thing, there was a pioneer. :) Be glad you replied to this thread today, because ... :smile: :wink:
There already is a formula for the kind of compound I mentioned (alkanes):
H = 2x C + 2
So it is C3H8 and C6H14.
H = 2x C + 2
What does that have to do with NO?
they're just proving that you can't just have hydroxide and h2o2 equal in your equations
  • · Replies 17 ·
11K
9K
