How Do You Form and Expand a Cubic Equation from Given Intersections?
  • Thread starter Thread starter Physiona
    Functional
30 replies · 4K views
Physiona
Shown below is the graph of
The graph interests the
axis at 3 points, B, C and D.
Given the points of intersection, and the brackets below, form and expand an equation for
the graph of
000000&chl=%28x%5C+%5C+%5C+%5C+%5C+%29%5C+%28x%5C+%5C+%5C+%5C+%29%5C+%28x%5C+%5C+%5C+%5C+%29%3D0.png
ATTEMPT:
I've assumed to involve the points of intersection for the x-axis which is 4, -2, and -5. It looks to be a cubic graph where x3. I'm not entirely convinced on how I progress from here if this way is correct. Any guidance? Thank you.
  • 000000&chl=%28x%5C+%5C+%5C+%5C+%5C+%29%5C+%28x%5C+%5C+%5C+%5C+%29%5C+%28x%5C+%5C+%5C+%5C+%29%3D0.png
Physiona said:
Shown below is the graph of View attachment 222920
The graph interests the View attachment 222921axis at 3 points, B, C and D.
the graph of View attachment 222922View attachment 222923
ATTEMPT:
When you factor a cubic, you get something that looks like ##(x-a)(x-b)(x-c)##. What do a, b and c represent?
ATTEMPT:
What does it mean for a polynomial ##f(x)## that ##f(a)=0\,##? What happens, if you divide such a polynomial by ##x-a\,##?
Will they not represent the points of intersection on the graph on the x axis? I'm not entirely sure
I don't understand your point clearly. At this stage I don't have the value of the equation of the function.
That's right. They are the roots of the equation, the values of x at which f(x) = 0. So if f(x) = (x-a)(x-b)(x-c), then . . . ?
Polynomials can be divided. This means for two polynomials ##f(x)## and ##g(x)## we can find polynomials ##q(x)## and ##r(x)## such that ##f(x)=q(x)\cdot g(x) + r(x)## with ##\deg r(x) < \deg g(x)##. Now insert ##a## in this equation with ##f(a)=0## and a suitable ##g(x)##.
Will ##(x-a)##= ##(x-5)## and ##(x-b)##= ##(x-2)## and then ##(x-c)##= ##(x+4)##
And then factorised out to form an equation is x3+4x2-2x2-8x-5x2-20x?
Not quite. You have a sign wrong in one of the factors.
Is ##(x+4)##, ##(x-4)##? Is that the error?
Nope.
tnich said:
Nope.
That is one error, but you have similar errors in the other factors. If a = -2, what is (x-a)?
Oh, hang on. Is it ##(x+2)## (because (x-(-2)) makes x+2..
And ##(x+5)##, and then ##(x-4)##?
Is this right?
Is this right?
Yes, that's right. Think about what it means to say f(x) = (x-a)(x-b)(x-c). If x = a, what can you say about f(x)?
Is this right?
You tell us!
Will ##f(x)## be ##f(-2)##? as under this circumstance, ##a=-2##..
That's true, but not what I was getting at. If f(x) = (x-a)(x-b)(x-c) and you substitute a for x in the equation, what answer do you get?
Will I have to substitute ##a=-2## in all of the polynomial do for x?
I.e. ##(x-b)## ---> ##(-2+5)##?
And then multiply them all out? Please correct me if I'm wrong as I'm not sure.
That is the basic idea, but try it and I think you will quickly see a shortcut.
And when you get your arithmetic all settled out, don't forget you are also given ##f(0) = -40## in the picture.
I get ##(-2+2)(-2+5)(-2-4)##
When I multiply it out I get zero for one set ---> ##(-2+2)(-2+5)## =0.
They all cancel out to zero. Meaning ##x## is zero..?
P.S: does ##y= f(x)## represent the y intercept by any chance? So ##f(0) = -40##?
The final equation I get is x3+3x2-18x-40
You started with f(x) = (x-a)(x-b)(x-c). Then you set x = a, so you substituted a for x in the equation to give you f(a) = (a-a)(a-b)(a-c) = 0. You can see that if you set x = a or b or c, you will get the same result. The point is, if you know what values make a polynomial equal to zero (the roots), you can write the polynomial.
Physiona said:
The final equation I get is ##x3+3x2-18x-40##
That's right.
Right that makes sense now. Thank you.
tnich said:
That's right.
I have another question if that's okay to ask? It's not based on the same topic though..
He should have started with ##k(x-a)(x-b)(x-c)## with ##k## unknown. It was just luck he got ##f(0)=-40##.
No. Start a new topic.
Erm, are you talking about me? I'm a female and I've finished the problem thank you very much. I know where I went wrong and my mistakes, and yes I did intend to do that method at the start just didn't post it on here as I was looking for an alternative to quickly approach if, so it wasn't luck. Thank you either way. :smile:
You're welcome. Sorry, hard to tell gender on these boards. Truth is, I don't know whether Physonia is a proper name in the first place, or, if it is, whether male or female.
