Graphing Phase & Trajectory Solutions: A Simple Guide
  • Thread starter Thread starter physicsss
    Graph
To graph the trajectory of a specific solution in a phase plane, one must plot the derivative of the function against the function itself, typically using MATLAB commands to create the plot. The discussion emphasizes the importance of initial conditions in determining the specific trajectory from an infinite number of possibilities in the phase plane. It also highlights that while the trajectory may appear linear over a limited range, it can actually be curved when examined more closely. Additionally, the correct approach involves calculating derivatives and forming a quotient to determine the slope of the graph. Overall, understanding these concepts is crucial for accurately representing the dynamics of the system.
physicsss
I know how to graph the phase plane of a general solution but how do I graph the trajectory of the specific solution given below?
Typically a phase plane is composed of an infinite number of trajectories. The initial conditions of a system determine which specific trajectory applies to the system with its given set of initial conditions. You have a specific equation - let's call it x(t). In order to draw its trajectoy we need to plot x'(t) VS x(t). If I were to plot this in MATLAB I would use the following commands
first I'm going to determine how long I want to plot this for
>>t = linspace(0,10,1000);
this makes a vector t that is composed of 1000 equally spaced numbers between 0 and 10.
>>xt = your given function here;
>>xpt = take the derivative of the function above and code it here;
>>plot(xt,xpt) this plots xpt on the y-axis and xt on the x axis
>>xlabel('x(t)')
>>ylabel('x dot(t)')
>>title('single trajectory of x(t)')
>>grid on this will add a grid to your plot for easier reading
If you are not familiar with MATLAB I can explain how to input the functions if you're having trouble. However, if you need to do this in maple or whatever, just use the same approach, however I cannot help you with the syntax using that program as I have no experience using it.
The system above can also be plotted even easier using SIMULINK if you have any experience with that. In fact, when using simulink all you need to do is input the differential equation and your IC's and you can do just about anything to the output.
Thanks, but I need to know how to do this by hand.
I assume you mean:
x_1(t)=1/4e^{-t}+7/4e^{-2t}
x_2(t)=-1/2e^{-t}+14/4e^{-2t}
In this case, if the ODE was written as:
\frac{dx_1}{dt}=f(x_1,x_2)
\frac{dx_2}{dt}=g(x_1,x_2)
Then the slope field is drawn in terms of the vector field:
F[x,y]=\langle f(x,y),g(x,y) \rangle
Then plot x_1(t)[/tex] and x_2(t) parametrically in the same coordinate space. Just do 10 of them should be enough to get a rough plot say from t=0 to t=2. You know the points (x_1(t),x_2(t)).
Does this look right?
Hey Physicsss. You know, I stated something incorrectly above regarding how to draw the slope field. I corrected it and hope that didn't cause confussion for you. Your plot looks Ok but it would be nice if you posted the ODE system. Also, it's a good idea to put an arrow at the end of the solution in order to identify the direction it's going.
The original problem didn't give the ODE system, only eigenvectors and their associated eigenvalues...and just one question, how do you know it's a straight path? I thought it should be somewhat curved since it's a linear combination of two things...
Well, x1 and x2 are given in terms of t parametrically but we're graphing them as x2 in terms of x1. Calculate the derivatives of both then form the quotient:
\frac{\frac{dx_2}{dt}}{\frac{dx_1}{dt}}
That becomes:
\frac{dx_2}{dx_1}
That then is the slope of the graph we get. What do you suppose will be the slope you get?
Physicsss, I made another mistake, Algebra this time. You know, the trajectory is not a straight line. It's just looks like one when you plot it from t=0 to t=2. Below is what it looks like closer to the origin (t>2). When we form the quotient of both derivatives, it's not constant as I initially thought but rather:
\frac{dy}{dx}=\frac{1/2e^{-t}-14/2e^{-2t}}{-1/4e^{-t}-7/2e^{-2t}}
Which is:
\frac{2\left(1/4e^{-t}-7/2e^{-2t}\right)}{-\left(1/4e^{-t}+7/2e^{-2t}\right)}
Sorry if I gave you the impression that it was a straight line. :blushing:
