How Do You Integrate √(1+x²)/x dx Correctly?
  • Thread starter Thread starter Saterial
    Integrating
6 replies · 2K views
Saterial
∫√(1+x2)/x dx
Let u = 1+x2
du = 2xdx
1/2du=xdx
x=√(u-1)
∫√1+x2/x dx
=∫√u/√(u-1) du
or is it 1/2∫√udu as xdx would remove it. This is where I got confused.
Saterial said:
∫√(1+x2)/x dx
Let u = 1+x2
du = 2xdx
1/2du=xdx
x=√(u-1)
∫√1+x2/x dx
=∫√u/√(u-1) du
What did you do with the x in the denominator of
[itex]\displaystyle \int \frac{\sqrt{1+x^2}}{x}\,dx \ ?[/itex]​
A better substitution would be a trig substitution such as x = tan(θ).
In my solution attempt, I tried two different ways. In your specific question, I replaced the x in the denominator with √(u-1) , as solving for x in u=1+x^2
You're missing an x.
You have du = 2x dx . Therefore dx = 1/(2x) du.
This gives you an x2 in the denominator. x2 = u - 1 .
A trigonometric substitution does the trick here, an hyperbolic substitution might also work.
Thanks for the help so far. With that little fix, I've now reached the point of
1/2 ∫√u/(u-1) du
I don't know where to go from here. I also am having many people tell me that this method will not work? That Trig-Substitution is the only way to solve this problem... Is that true? Am I just wasting my time?
1/2 ∫√u/(u-1) du
There are two ways that I know of to do this integration.
Use either a trig substitution, such as x = tan(θ) , or use a substitution involving hyperbolic functions, such as x = sinh(u).
These are handy because, tan2(θ) + 1 = sec2(θ) and sinh2(u) + 1 = cosh2(u).
Either substitution will require you to do a far amount of follow-up work to finish the integration.
