How do you program with Fortran 95?
  • Topic: Fortran
  • Thread starter Thread starter kathrynag
    Program
12 replies · 9K views
kathrynag
Fortran 95!
Does anyone know how to program with Fortan 95? I need some help!
Something specific:
I'm trying to write a program in Fortan 95. I need to find the distance between 2 points (x1,y1) and (x2,y2) on a Cartesian coordinate plane given by the equation:
d=sqrt[(x1-x2)^2+(y1-y2)^2].
I want to use the points (-1,1) and (6,2).
This is the copy of what I am doing:
program distance
!kathryn, Assignment 2-21, calculate distance between two points.
implicit none
real::x1 !This is the x from the first ordered pair.
real::y1 !This is the y from the first ordered pair.
real::x2 !This is the x from the second ordered pair.
real::y2 !This is the y from the second ordered pair.
real:: d !This is the distance we are trying to find.
write(*,*) 'This program calculates the distance between two points
+ on a Cartesian coordinate plane.'
read(*,*) d
d=sqrt((x1-x2)^2+(y1-y2)^2) !Calculation
read(*,*) 'The distance between any two points ,'(x1,y1)', and ,'(x2,y2)', is ,'d
end
My problem is that when I compile, I get errors. Where am I going wrong?
mgb_phys said:
I don't know f90 but what are the error messages ?
i don't know right off hand, but it's f95.
there's no real difference, between Fortran90 and Fortran95,
The compiler error should at least tell you which line the problem is on.
Is ^ a new operator in f95 It used to be '**' in f77 ?
Ok, well I could try it again. I can't run it on my comp. I'll have to try a different one.
I think there are two bugs:
(1) The exponentiation operator is (**) in F95, not (^)
(2)The read statement before end program should be write instead
Ok, I'll try those, but I still got errors. Is the last read statement fine other than the write?
Hi kathrynag
It looks like that there are some synatax errors and a logical one actually.
(1) In your code you wrote
Code:
The continuation operator in Fortran is "&" not "+", so a valid statement is
Code:
write(*,*) 'This program calculates the distance between two points &
 & on a Cartesian coordinate plane.'
(2) A logical error in this statement:
Code:
read(*,*) d
You are supposed to ask the user to enter the coordinates x1,x2,y1,y2 , not the distance . After all your code should calculate the distance when the user enters the coordinates. So a valid statement should be
Code:
read(*,*) x1, y1, x2,y2
(3) This statement has some syntax erros:
Code:
A better one is :
Code:
write(*,*)'The distance between any two points ,',x1,y1,', and ,',x2,y2,', is ,',d
Compare them.
(4) Finally, if you are using fixed format file, make sure that none of the lines is longer than 80 columns. If any is longer, use the continuation operator "&"
Hope that works for you
Ok, I'll try those and let you know what happens.
should I do read(*,*) x1,x2,y1,y2 or separate lines for each variable?
It is fine as you wrote it.
I got it all figured out except for the extension of a line. It works fine if I don't extend a line.
