How do you project a Killing Vector onto a Schwarzschild field?
The discussion revolves around the mathematical projection of a Killing vector onto a Schwarzschild field of spacetime. Participants explore the meaning and implications of this projection, particularly in relation to black and white holes within the context of Schwarzschild spacetime.
  • Some participants question the clarity and meaning of the original question regarding projecting a Killing vector onto a Schwarzschild field.
  • There is a request for references to clarify the intent behind the projection of a black and white hole onto Schwarzschild spacetime.
  • One participant asserts that Schwarzschild spacetime inherently includes both black and white holes, suggesting that the question may be based on a misunderstanding.
  • Another participant proposes the use of Kruskal coordinates for visualizing the maximally extended Schwarzschild solution.
Participants generally express disagreement regarding the formulation and validity of the original question, with no consensus on how to approach the projection of a Killing vector in this context.
There are unresolved assumptions about the definitions and implications of projecting a Killing vector, as well as the nature of black and white holes in relation to Schwarzschild spacetime.
bobrubino
TL;DR
What is the math for projecting a Killing vector onto a Schwarzschild field of spacetime?
What is the math for projecting a Killing vector onto a Schwarzschild field of spacetime? How would you do it?
What is a Schwarzschild field? Is this meant to be "B" level?
The question doesn't make sense. Can you give a reference that explains what you are trying to do?
I am trying to project a black and white hole onto a field of Schwarzschild spacetime and I don't know what to do. Do you have any advice?
Your question still doesn't make sense. Again, where are you getting this from? What makes you think this is even a meaningful thing to do? Why do you want to do it? A reference would be helpful.
Schwarzschild spacetime is a black hole and a white hole. Your question makes no sense.
Are you trying to find the spacetime for a binary blackhole? You can't do it by adding together two copies of the solutions for one black hole.
The maximally extended Schwarzschild is both a black hole and a white hole. If you are just trying to visualize that, my preference is Kruskal coordinates
  • · Replies 32 ·
  • · Replies 38 ·
  • · Replies 16 ·
  • · Replies 16 ·
