How Do You Prove Trigonometric Identities with Minimal Equations?
  • Thread starter Thread starter alexandria
    identities
alexandria
prove the following identity [/B]
no equations required
I've been trying to prove this identity, but no matter what I do, I can't seem to make both sides the same
here is my answer to this qts so far: can someone please tell me what I have to do next?
Im pretty sure I'm supposed to be getting tan(x) - 1 on both sides. So, should I leave the left side the same (keep it as tan(x) -1) and work only with the right side, until both sides are equal?
any help would be appreciated. Thanks.
Sorry for accidently posting the same thread twice :p
View attachment 104677Sorry for accidently posting the same thread twice :p
When you divide a sum or difference, you have to divide all terms. ##\frac{\sin(θ)-\cos(θ)}{\cos(θ)}## is not sin(θ)-1. And you made the same error in the right side.
Leave the left side as it is, and work with the right side. Divide both numerator and denominator with cos2(θ), for example.
Thanks for the quick reply!
Ok so i understand that i am supposed to leave the left side the same, but what do i do with the right side. You mentioned dividing both numerator and denominator with cos^2(θ), how do i do that?
so is it:
sin^2(x) - cos^2(x) /cos^2(x)
sin(x) cos(x) + cos^2(x) / cos^2(x)
i was originally using trigonometric identities:
for ex: sin^2(x) + cos^2(x) = 1 so i was assuming that sin^2(x) - cos^2(x) = -1
and so i replaced sin^2(x) - cos^2(x) with -1
is this correct?
so is it:
((sin^2(x) - cos^2(x)) /cos^2(x)
(sin(x) cos(x) + cos^2(x)) / cos^2(x)
No. You have to divide the whole expressions, not only the last terms. Do not omit the parentheses.
is this correct?
No. It is wrong. sin^2(x) - cos^2(x) is not -1. Try with numbers. 2/3 + 1/3 = 1, is it true, that 2/3 - 1/3 = -1?
so is it:
is this correct?
sin^2 x + cos^2 x = 1
=> -sin^2 x - cos^2 x = -1 and not what you wrote.
Leave the left side as it is. In the right side, we notice that we can use the formula: a^2 - b^2 = (a-b)(a+b) in the numerator. Try to find the factors of the denumerator and the problem becomes quite trivial then.
ok so for the right side,if I use the formula: a^2 - b^2 = (a-b)(a+b)
then it becomes:
(sin(x) - cos(x)) (sin(x) + cos(x))
how do i solve this??
You're not getting the right push so far. You need to show that a = b/c. Thus ac = b. Cross-multiply (tan theta - 1) by the denominator (sin theta cos theta + cos^2 theta) theta and simplify.
srry I am very confused, what do you mean by cross multiply and why would I need to cross multiply tan(x) - 1 by the denominator of the right side?
Can you provide an example!
ok so i came up with an answer, can someone tell me if I am on the right track?
= tan^2(x)
tan(x) + 1
= tan(x) tan(x)
tan(x) + 1
= tan(x) + 1
im not sure what to do from here.
= tan^2(x)
tan(x) + 1
The last equation is wrong.
can you please elaborate?
Look at that numerator again !
What is ##\displaystyle \frac{\sin^2(x) - \cos^2(x)}{\cos^2(x)} \ ## ?
It's not
= tan^2(x)
You may need to review: adding and subtracting fractions !
for the numerator:
sin^2(x) - cos^2(x) / cos^2 (x)
inorder to find the answer, I have to divide cos^2(x) by each term in the expression:
so sin^2(x) / cos^2(x) = tan^2(x) (since sin(x)/cos(x) = tan(x))
and -cos^2(x) /cos^2(x) = -1
so is the answer tan^2(x) - 1
alexandria said:
for the numerator:
then it becomes:
Factor out a cosx in the denumerator:
[sin^2 (x) - cos^2(x)]/[sinxcosx + cos^2 x]
= [(sinx - cosx)(sinx + cosx)]/[cosx(sinx + cosx)]
Then use (a+b)/c = a/c + b/c
alexandria said:
for the numerator:
(sin^2(x) - cos^2(x)) / cos^2 (x)
Yes.
So make that correction in the following.
= tan^2(x)
tan(x) + 1
That gives
## \displaystyle \frac{\tan^2(x) - 1}{\tan(x)+1} \ ##
(sin(x) cos(x) + cos^2(x)) / cos^2(x)= tan^2(x) - 1
tan(x) + 1
= tan(x) - 1
is this correct?
tan(x) + 1
= tan(x) - 1
is this correct?
That is correct.
Can you justify that last step ?
ok so,
tan^2(x) - 1
tan(x) + 1
= tan(x) tan(x) - 1
------------------ ( I am pretty sure tan(x) crosses out at this part)
tan(x) + 1
= tan(x) - 1 / 1
= tan(x) - 1
is this process correct?
alexandria said:
ok so,
tan^2(x) - 1
tan(x) + 1
= tan(x) tan(x) - 1
tan(x) + 1
= tan(x) - 1 / 1
= tan(x) - 1
That's what I suspected.
That is not the correct way to obtain the result.
a2 -1 factors to (a - 1)(a + 1)..
So, can you factor ##\ \tan^2(x) - 1 \ ?##
ok so,
(tan(x) - 1) (tan(x) + 1) (cross out the expression tan(x) + 1)
tan(x) + 1
= tan(x) - 1
alexandria said:
ok so,
tan(x) + 1
= tan(x) - 1
That's more like it !
thanks so much for all the help, I really appreciate it! :smile:
Well take RHS.
cos θ is obviously a factor of the denominator. So factorise it.
Now look at the numerator. This is the difference of two squares. Know how you can factorise - OK how you can write difference of two squares? (a2 - b2)?
Do that then you see one of the factors is the same as the factor of the denominator. Then it all falls out easily.
Why can I do that in my head, and you have spent an hour on it? Well partly it's because I don't have to do it. So I'm relaxed about it You might need to relax
Secondly I'm using a Polya 'How To Solve It' principle - asking self "have you seen anything like this before?".
Sure you see trig the formula and you start thinking of other trig formulae – you might not recognise immediately the resemblance with (a2 - b2). That may be where being relaxed helps
Prove the identity:
Can someone tell me if this is correct? I am not sure if I should have worked on both the right and left side until they were the same, instead of just the left side?
Evangeline101 said:
Prove the identity:
Looks okay,
The second step on the left hand side is a bit strange, but then you fixed it the next step, so probably just a typo.
This step?
should I just take it out then?
Evangeline101 said:
This step?
The next step, it's not equal to ##\frac{\sin{x}+\sin{x}}{\cos{x}}##
It seems to me that working the right hand side would be easier than working the left hand side.
Student100 said:
The next step, it's not equal to sinx+sinxcosx
Okay, I edited it:
Is this better?
  • · Replies 69 ·
12K
