How Do You Solve Matrix Equations with a Calculator?
4 replies · 3K views · last reply
KF33
Poster has been reminded to show their work on the problem in order to get our tutorial help
I know I would have to do something with my calculator and I tried to solve like solving an equation for C, but not sure. I put all the matrices in my calculator. I then subtracted the first matrix to the other side then multiplied by the inverse of the second. That got my out a 3x3 matrix, but not sure if that means that is the solution.
That sounds like the correct thing to do. If you are unsure, put your answer in and see if it works.
Substituting your answer in the original equation is a good idea in any case. As you progress in mathematics, some of the calculations get very involved, and there are lots opportunities to make small errors. Once you reach a solution, you can confirm that your answer is correct by substituting it in the problem. If you end up with two equal expressions, that's a strong indication that your solution is correct.
Charles Link said:
From the looks of it, ## C ## must be a 3x3 matrix.
Either it's a 3x3 matrix or a scalar. It should be easy to verify whether or not a scalar could be a possible solution.
