How Do You Solve Relativity Problems with Perpendicular Velocities?
  • Thread starter Thread starter Electrophy6
    Relativity
13 replies · 2K views
Electrophy6
Rocket "A" velocity is 0.8c to the right ,reltaive to earth
Rocket "B" velocity is 0.6c to the left , relative to rocket "A"
(This one I succedeed)
My problem was in this question:
Repeat the same problem ,but bow rocket "A" moves 0.8c * upwards *(positive y axis)
For some reason , I didn't make well
Tried using these equation while:
V=0.8,vx'=-0.6c,vy'=-0.8
Now , I know I got something wrong but I couldn't figure it out by myself(although I tried)...
Thank you!
Hello.
Please state what the question is asking for.
Oh sorry ,forgot the th most important part
The question is :
"What is the velocity of Rocket B , relative to Earth ?"
The question is :
OK
Just to be totally clear, what frame are you taking to be the "unprimed" frame? Is it the Earth frame, the A-rocket frame, or the B-rocket frame?
Same question for the "primed frame".
Ok ,let's use the following notations
Earth- S
Rocket A- S'
Rocket B- S''(not necessary)
For your list of relevant equations, what basic assumption is made about the direction of the velocity of the primed frame relative to the unprimed frame?
let's say we define the "right" to be the x positive direction and assume rocket A (O') moves in this direction realtive to O (originally S ,S' but it doesn't matter)
Oh sorry again ,wrong diagram
S' goes in the y positive direction(upwards) relative to S
OK. Back to my earlier question. The equations that you wrote down as the Relevant equations are only valid if the primed frame moves in what direction relative to the unprimed frame?
Sorry , I misunderstood the question
However ,I will try answering it: I guess these equations are true If S' goes to the right relative to S
(So ,does it mean ,they can't fit the directions I just presentd ?)
The formulas you listed assume that the primed frame is moving in the x direction relative to the unprimed frame.
Since rocket A (frame S') moves in the y direction relative to the Earth (frame S), you will not be able to use the equations as written.
Can you see how to modify the equations so that they are applicable?
Maybe ...
in the eqaution of vx should I use Vx
-----------------vx-------------------Vy
-----------------vz------------------Vz
Electrophy6 said:
Maybe ...
I'm not sure I'm following you here.
In the equations that you listed, the relative motion of the two frames is assumed to be along the x direction. In your problem the relative motion is along the y direction. So, you can just replace all the x and x' subscripts in the equations by y and y' subscripts. Likewise, replace all y and y' subscripts in the equations by x and x' subscripts.
Ohhh you are right
Thank you very much for your patience and for your help!
