How Do You Solve Simultaneous Equations Using Quadratic Methods?
9 replies · 3K views
maali5
How do yo solve simultaneos equations?
Am I right ?
y = x2 – 5x + 5 question a
5x + 3y = 30. question b
Find location of points collide?
Add a+b
x2 + 2y -25=0
quadratic formula use
x= -2+ square root(2^2-(4x1x(-25))/2 x = 4.09901
or
x= -2 - square root(2^2-(4x1x(-25))/2 x=-6.09
subsitue y etc
Am I right ?
Add a+b
x2 + 2y -25=0
or
subsitue y etc
Looks like you are on the right track...
Cheerio
maali5 said:
Add a+b
x2 + 2y -25=0
I would use substitution. You already have equation a solved for y. Plug it into equation b:
5x + 3y = 30
5x + 3(x2 – 5x + 5) = 30
... and so on.
Errrm, if eumyang is on the right track, then I'll eat my hat!
... and I'll post the video of it on youtube.
maali5 said:
x2 + 2y -25=0
x= -2+ square root(2^2-(4x1x(-25))/2, x = 4.09901
or
x= -2 - square root(2^2-(4x1x(-25))/2, x=-6.09
substitute y etc.
You can't use the quadratic formula on x2 + 2y -25=0, because it has two different variables in it.
B.T.W: Yesterday, Mark44 pointed out to you that you should not use the lower case letter, x, to indicate multiplication.
Hey ladies ;) + gentleman :)
Now you have "REALLY" lost me.
I went with eumyang- subsituations and this is what I have done.
NB: Allright I WILL USE . FOR MULTIPLY NOW
Ok, let's start
1)
y = x^2 – 5x + 5 question a
5x + 3y = 30. question bFind location of points collide?
Answer;5x + 3(x^2 – 5x + 5) = 30
5x+ 15x^2 -15x+15=30
15x^2-10x+15=30
15x^2-10x -15 = 30
5(3x^2 -2x -3) = 30
use formula
x= 2 + sqrt{40} / 6
x= 1.3874
or
x=2 - sqrt{40} / 6
x= -0.72075Is this the right directions?
maali5 said:
Answer;
The coefficient of the x2 term is 3, not 15.
15x^2-10x+15=30
15x^2-10x -15 = 30
5(3x^2 -2x -3) = 30
use formula
x= 2 + sqrt{40} / 6
x= 1.3874
or
x=2 - sqrt{40} / 6
x= -0.72075
Once you get a solution for x, you should go back to an original equation to find y. To check your answer for the pair x & y, you should then plug those values into the other original equation.
CORRECTION: I intended to write
Errrm, if maali5[/color] is on the right track, then I'll eat my hat!
You must make the right hand side = 0 before using the quadratic formula.
Taking as an example: 15x^2 - 10x - 15 = 30
Make RHS=0:
15x^2 - 10x - 15 - 30[/color] = 30 - 30[/color]
x = (10 ± sqrt(100 + 4•15•45)) / 30
