Education Advisor
- 3,215
- 3,848
mgb_phys said:Do you have to manually pressurize the primary circuit in a PWR or do you rely on the water boiling when it starts up to self pressurize?
In a PWR, the pressurizer begins solid (full of liquid) at ambient pressure & temperature - they first 'draw a bubble' in the pressurizer by operating the heaters to bring the pressurizer fluid to saturation, and then draining some liquid from the primary loop. This flashes some steam, creating the bubble. The pressure is then raised by operating the heaters until there is adequate pressure (around 150 psi) to operate the main reactor coolant pumps (they need pressure for adequate suction, and for their seals). Once a reactor coolant pump is running the primary system heats up due to the pump heat. In a commercial plant each reactor coolant pump is about six thousand horsepower, so they put a lot of heat into the water and it doesn't take too long to bring the system to operating temp & pressure.
After that the pressurizer heaters run to counteract the heat losses from the system to ambient, and to accommodate a small trickle flow through the spray line (this small flow keeps the spray line and its nozzle 'hot' to avoid the thermal shock that would otherwise be seen when the spray was turned on. The control system monitors the pressurize pressure and turns the power to the heaters up and down to maintain pressure within the desired band.
