How Does a Spring Scale Measure the Total Force in a Balanced Meter Ruler Setup?
5 replies · 6K views
xiaomeizi
A uniform metre ruler of weight of 1.2N suspended at its mid-point from a spring scale which is calibrated in Newton(N).
An apple with weight of 0.75N, suspended from the metre rule at the 10cm mark, is balance by a weight of 1N, which is suspended from the 80cm mark. Assume g=10N/kg.
Q. what is the reading on the spring balance?
The reading on the spring balance= weight of both apple and the 100N. (0.75N+1N=1.75N)
I don't understand the answer. what about the weight of the metre ruler, balanced out by the upwards force ? I thought the spring scale is used to measure the tension, if that is the case, the tension should include the weight of the metre rule, isn't it ? could anyone dismiss my doubts? Thanks you. :D
Turning effect of force (Moments)
The reading on the spring balance= weight downwards due to gravity
the answer suggested that (0.75N+1N=1.75N)
BUT, I don't understand the answer. what about the weight of the metre ruler, balanced out by the upwards force ? I thought the spring scale is used to measure the tension, if that is the case, the tension should include the weight of the metre rule, isn't it ? could anyone dismiss my doubts? Thanks you. :D
Yes, you are correct, the scale should read 2.95 N. Perhaps the scale was precalibrated to 0 with the meter stick alone on it? Like when you weigh a bunch of potatoes on a spring scale in a food store, the scale is adjusted to 0 with the pan weight alone on it, so you don't get overpriced. But the problem is not clear in that regard.
hi xiao
yes, the answer seems wrong. since the ruler is neither moving nor rotating, we have to use
the stability condition for the force. when we do that , the answer given seems wrong as it neglects the weight of the ruler...
IssacNewton said:
hi xiao
Thanks for your reply.
