xiaomeizi
- 6
- 0
A uniform metre ruler of weight of 1.2N suspended at its mid-point from a spring scale which is calibrated in Newton(N).
An apple with weight of 0.75N, suspended from the metre rule at the 10cm mark, is balance by a weight of 1N, which is suspended from the 80cm mark. Assume g=10N/kg.
Q. what is the reading on the spring balance?
The reading on the spring balance= weight of both apple and the 100N. (0.75N+1N=1.75N)
I don't understand the answer. what about the weight of the metre ruler, balanced out by the upwards force ? I thought the spring scale is used to measure the tension, if that is the case, the tension should include the weight of the metre rule, isn't it ? could anyone dismiss my doubts? Thanks you. :D
