How does a surjection from countable to A imply A is countable?
8 replies · 3K views · last reply
Danijel
I know there are many proofs of this I can google, but I am interested in a particular one my book proposed. Also, by countable, I mean that there is a bijection from A to ℕ (*), since this is the definition my book decided to stick to. The reasoning is as follows:
ℤ is countable, and so iz ℤxℤ. Since ℤ*=ℤ\{0}⊂ℤ, ℤxℤ*⊂ℤxℤ, ℤxℤ* is countable (since every infinite subset of a countable set is also countable). Now, from the construction of ℚ, we know that ℚ=ℤxℤ*|~, ℚ is the image of τ:ℤxℤ*→ℚ, so ℚ is either finite or countable. Since ℤ⊂ℚ, ℚ is countable.
I understand everything except the part "ℚ is the image of τ:ℤxℤ*→ℚ, so ℚ is either finite or countable"(**), since this is not proven anywere. Maybe it is obvious, but I haven't grasped it. I've found few similar proofs of this statement, but they all consider A being countable if there's an injection from A to ℕ, whereas my book insists on a bijection. So my question is, how do I deduce (**) from (*)?
So, I thought about this, and this is what I have concluded. Since there is a surjection from ℤxℤ* to ℚ, then there is injection from S⊂ℤxℤ* to ℚ, which means that there is a bijection from S to ℚ. Since ℤ⊂ℚ, ℚ is infinite, but then S is infinite too. Since S is an infinite subset of a countable set, it is also a countable set. Now, since there is a bijection from S to ℚ, it follows that there is a bijection from ℚ to ℕ, so ℚ is countable by the definition. Is this right? However, I still don't know about the part"finite or countable", since I have only considered the countable.
What book are you referring to? and what pages?
This may help another poster in answering your question. Calling @fresh_42
Also, try not to post twice in a row and instead just edit your original post with the additional content.
This book is in Croatian, and you can say it is not really a book, more like a compilation of notes made by one of our professors.
Also, sorry for posting twice. I didn't know about the convention.
The book by K.Kuratowski, A.Mostowski, Set Theory, is mentioned in the bibliography.
##\tau ## is a projection, so it is neither injective (subset) nor bijective (equal). ##\mathbb{Q}= \mathbb{Z}\times \mathbb{Z}^*/ \sim ## where the equivalence is defined by ##(a,b)\sim (c,d) \Longleftrightarrow ad=bc##. This means, that ##\operatorname{im}\tau = \mathbb{Q}## has at most as many elements as ##\mathbb{Z} \times \mathbb{Z}^*## has, possibly less. That's where the possibility of finite many comes into play and why ##\mathbb{Z}\subseteq \mathbb{Q}## is needed as an argument, to rule this out.
The proof doesn't establish a direct bijection as required for ##(*)##. Instead it uses properties of subsets and images under mappings. These properties have to be proven first and that's where the connection to ##(*)## occurs. If you want to deduce it directly from there, you'll have to use another proof or combine all previous statements to a long, new one: "If ##B \subseteq A## and ##A## is countable then ##B## is countable." + "If ##A## is countable and ##f\, : \, A \longrightarrow B## is a projection, then ##B## is countable." + "the proof above".
So is my 2nd post incorrect? I know that the given projection is not injective, but it is surjective. Can we then restrict it to an injective one, and get a new function from a subset of the domain to the codomain? From here it follows that the second set is either finite or countable. Anyways, thank you for your reply.
Yes, that's what the equivalence relation does. It restricts all pairs of ##\mathbb{Z}\times \mathbb{Z}^*## to equivalences classes, because ##\frac{1}{2}=\frac{2}{4}=\ldots ## Of course you can also count those quotients as different, in which case you get a bijection, but to count ##\frac{0}{1}## and ##\frac{0}{z}## as ##\mathbb{Z}^*-##many elements isn't very convincing.
