How Does an Implosion Engine Work?
  • Thread starter Thread starter monty37
    Engine Implosion
21 replies · 12K views
monty37
what is an implosion engine?
Something someone made up?
From the (rather wooly) name of the engine. You'd have to say it's an engine that works on the principle of 'something' making a vacuum pulling a cylinder (or whatever, I use cylinder because it's easy to visualise) instead of positive pressure acting to push it. Quite how that would be achieved in the sense of an engine I don't know.
But to be honest it's sounds like some ******** 'scientific' name made up to give something credibility, where none is deserved.
Links to said engine?
EDIT: The more I think about it, the more it screams of the free energy crowd. so... IBTL.
Don't you mean an explosion engine? I mean, a combustion engine?
but what about the exhaust ?and is how is this implosion effect enough to drive the piston.
eh... It's most likely made up nonsense anyway, so the exhuast is irrelevent.
You are the one who asked about it, where did you hear about it? Can you post some links to I know what on Earth you are on about.
I truly believe you misunderstood the name of the engine. I mean, in an explosion engine, thne piston will be driven by the combustion of the fuel+air mixture...
Sorry for my bad English, but I'm not a native speaker.
Milena
Milena
He's not misunderstood, he's read somewhere about a 'new' engine and is asking what it is (but is seemingly not willing to post where he's read about it). I'm saying it's a crock of ****.
He's quite obviously knows what a normal engine is, he just wants to know what this 'implosion' engine is.
ok .i was looking for various principles in engines apart from combustion so ..i stumbled onto this implosion engine.i found it on freepatentsonline .
this thing has also got a patent then why is it nonsensical
because you can patent anything you want, it doesn't have to acutally work. The patent office don't check if it works or not.
All sorts of crackpot **** is patented, it doesn't mean a thing.
It may or may not be nonsensical, but unless you give us a link to the patent, we can't tell!
Last chance, monty: give us a link or this thread has to be locked.
Summary of the patent: A piston cylinder setup containing a liquid and a gas with a strong affinity to absorb into the liquid. The gas wants to absorb so much that it will reduce the pressure in the cylinder, causing the piston to contract reducing the volume and producing force on the piston.
I'll have to ask a chemical engineer, but I can't imagine a situation where a gas so rapidly wants to dissolve in water that it is even possible to drop the pressure above the liquid. And if this did happen, it would probably very slow relative to an internal combustion engine.
Think about this in terms of energy density as well. A conventional hydrocarbon fuel has a lot of chemical potential energy, and the second component in the combustion reaction (oxygen) doesn't need to be carried in a tank as it is pulled in from the atmosphere. This implosion engine would need to carry a very low density gas and a lot of water. And due to the slow contraction of the piston, many pistons would be required because I can't imagine getting more than 1 RPM out of this thing. The patent mentions that the gas could be stored as a liquid at high pressure between 2-20 bar, but the energy required to compress this gas will likely consume more energy than you could get back out of the system.
My initial conclusion: Plausible concept, but totally inefficient and worthless!
[...] I can't imagine getting more than 1 RPM out of this thing. [...] totally inefficient and worthless!
So you never did the simple science experiment of imploding a coke can? It happens with a bang, too fast to see, when the opening of the vapour-filled can is pressed against the liquid. In fact, if it were slow, it would just siphon in the liquid instead of mangling the aluminium can.
I think you're too hasty, making asertions about efficiency based purely on your lack of imagination.
haha fair enough, but I've been reading into energy density of transport fuel a lot lately and this seems to me at first glance like it wouldn't be efficient.
I've never seen the coke can experiment, can you explain it in better detail?
  1. Procure a can of coke, and pour down toilet. It'll do far more good for the porcelain than it would for your body.
  2. Pour a few mL or so of water into the bottom of the empty aluminium can.
  3. Heat the can, and get the water to a boil for about a minute. This is so water vapour displaces most of the air inside the can.
  4. Invert the can and quickly lower (opening first) into a tub of cold water.
There is some potential to get hurt doing this, so think carefully beforehand. Tongs, safety glasses..
Oh yes, I've done that experiment before. I won't argue against boiling and condensing water as a powerful way to extract energy because that is the most prolific thermodynamic cycle we use for power generation, meaning the Rankine Cycle.
But this patent seems to be about dissolving gas (he states Ammonia) into water, not just phase changing the water.
I should mention that one of the reasons I was so eager to pooh-pooh this idea is because it was filed in 1976 and none of us has ever heard of it!
monty37 said:
http://www.freepatentsonline.com/3975914.html
here is where i saw it. the liquid and gas is being brought together and ..absorption..vacuum..?
Yup. It's an Einstein-Szilard refrigerator with "mechanical stuff" added between the stages.
I'll side with CS Bence, and second his conclusion;
It's still a pressure differential causing movement, but with this system you are limiting yourself to a maximum differential of 1 bar by creating a vacuum.
With combustion you have a differential of 600odd bar pushing the piston.
