How Does Applying a Force Change an Object's Velocity?
  • Thread starter Thread starter physsurveyor
    Momentum Variation
4 replies · 2K views
physsurveyor
If a 1kg object is moving at 3m/s in a positive direction, and a 12N force is applied in the negative direction, what is the velocity immediately after 2s?
I'm fairly sure this will be a variation of relevant momentum equations, and/or mixed with kinematics, yet I'm not seeing the correct application. I lean towards answers c or b.
Obviously mo will be conserved.
conservation of mo: m1Vi= (m1+m2)vf t=v/a
a. 12m/s
b. 6 m/s
c. 3 m/s
d. 0 m/s
Please explain.
I'm afraid you can't use conservation of momentum here - that only applies in the absence of an external force (in the relevant direction), and here the problem says there's a 12 N force. Do you know any other way you might go about solving this?
What you need is the impulse formula. Whenever time is involved for a force it's almost always Impulse.
Definition: The Impulse (I) imparted onto a body is the change in it's momentum. Impulse is a vector quantity.
Derivation: F = ma
F = m (v-u)/t
F = mv - mu /t
Ft = mv -mu
Unit is obviously Newton seconds.
Yes, I do believe this is on the right track, so thanks, but
I believe I'm remiss in something. What is u?
I'm recalling something like...Ft=mvf-mvi (change in p)
u = initial velocity
