How Does Changing Plate Distance Affect Interference Patterns in Interferometry?
  • Thread starter binbagsss
    Interference
binbagsss
- why is it that fewer rings are observed when the plates are moved closer together (given wavelength , monochromatic source). What equation shows this relation?
- Consider a non-monochromatic source, such as a Sodium Lamp, as the distance varies, both patterns change but at different rates - one will change at a faster rate than the other - which one changes quicker - the D line with the greater or smaller wavelength? And why is this, again is there an equation to show this relation?
- As the distance between the plates is changed, the number of rings observed changes also - are there any other observable affects varying with this distance?
Thanks a lot anyone for any assistance !
also see: your other thread about this interferometer for the context.
http://hyperphysics.phy-astr.gsu.edu/hbase/phyopt/fabry.html
Take a look at the geometry panel - when the path difference (length CD) is an integer number of wavelengths you get constructive interference and thus a maxima. CD depends on the angle and how far apart the plates are by simple geometry.
To understand this - sketch the diagram with different plate separations.
Again, it is the path difference equation ... the path difference needs to be a whole number of wavelengths.
Work it out.
What sort of effect did you have in mind?
