PhDeezNutz
- 858
- 568
- Homework Statement
- In my book (Electric Circuits by Nilsson and Riedel) it states
"Whenever a positive and negative charges are separated, energy is expended). Voltage is the energy per unit charge created by the separation. We express this ratio in differential form
##V = \frac{dw}{dq}##"
##v## = voltage in volts
##w## = energy in joules
##q## = charge in coloumbs
It also says a few pages back that one of the assumptions of circuit-theory is
"The net charge on every component in the system is always zero. Thus no component can collect a net excess of charge, although some components, as you will learn later, can hold equal but opposite separated charges"
I'd like to derive the equation for ##V##
- Relevant Equations
- See above
The statement
leads to believe that we are always dealing with charges of equal magnitude but opposite sign in circuit theory so that is how I will proceed.
Suppose we have two equal but opposite charges
## F = -\frac{q^2}{4 \pi \epsilon_0} \frac{1}{r^2} ##
Work done in separating charges (by some external influence)(minus sign because the it opposes the field)(i.e. energy lost)
##W = - \int F \, dr = -\frac{q^2}{4 \pi \epsilon_0} \frac{1}{r} ##
Now when it says ##V = \frac{dW}{dq}## I get
##V = - \frac{q}{2 \pi \epsilon_0} \frac{1}{r}##This goes against my intuition (possibly wrong intuition) that the actual expression for ##V## is
##V = \frac{q}{4 \pi \epsilon_0} \frac{1}{r}##
Where did I go wrong?
