How Does Diffraction in Water Affect Light Angles Compared to Air?
The discussion centers on how diffraction in water alters light angles compared to air, particularly when using a plane grating. It is established that the speed of light in water is approximately 1.3 times slower than in air, which affects the wavelength of light. This change in wavelength leads to different diffraction angles as described by the equations d sin(θ) = mλ and a sin(θ) = mλ. Consequently, the resulting diffraction pattern exhibits wider and narrower angles when submerged in water.
  • Understanding of Snell's Law
  • Knowledge of wave properties of light
  • Familiarity with diffraction equations
  • Basic concepts of refraction in different media
  • Study the principles of Snell's Law in detail
  • Explore the relationship between wavelength and medium in optics
  • Investigate the effects of different media on diffraction patterns
  • Learn about the applications of plane gratings in optical experiments
Students in physics, optical engineers, and anyone interested in the behavior of light in different media, particularly in relation to diffraction and refraction.
zzizi
Hi
Could someone explain to me... if a diffraction experiment that had a plane grating on it was submerged into water...why the diffracted light would produce extra angles that are wider and narrower than if the experiment had been carried in air?
Snells law?
Does it have something to do with refraction?
I would really appreciate an explanation, thanks.
assuming that the frequency of the light being used does not change in or out of the water then the wavelength must change as a result of the differing speeds of light. i.e:
frequency = velocity / wavelength ([tex]\lambda[/tex])
so, solving for [tex]\lambda[/tex], [tex]\lambda[/tex] = v/f.
in a vacuum (or near vacuum, i.e. air) v = c. However, in water v = c/~1.3, resulting in a [tex]\lambda[/tex] which is significantly different.
so, your diffraction equations:
d sin ([tex]\theta[/tex]) = m [tex]\lambda[/tex], and a sin([tex]\theta[/tex]) = m[tex]\lambda[/tex]
are now using significantly different values, resulting in significantly different values for [tex]\theta.[/tex]
Thank you so much.
14K
