How does e^(2iz) = -1 lead to 2iz = πi + 2kπi?
7 replies · 3K views
nickolas2730
Prove that cos z = 0 if and only if z = π/2 + kπ, where k is an integer.
The solution is :
cos z = (eiz+e-iz)/2 = 0
<=>eiz+e-iz)=0
<=>e2iz=-1
<=>2iz=πi +2kπi
<=>z=π/2 + kπ
But i don't understand how does these 2 steps work
<=>e2iz=-1
<=>2iz=πi +2kπi
how can a exp function suddenly become πi +2kπi
Thanks
i know there is an equation :
ez1=ez2 holds if and only if z1=z2 + 2kπi
But how can i know in exam -1 = eπi
is it by try an error
It's hard to explain why those things hold because I don't know what I can use and what I cannot use.
How did you define the exponential?? What properties have you already seen about the exponential??
Is there a book you're reading where this appears in?? Lecture notes??
Yes, this is what you use.
Knowing this depends on what you know about the exponential. I can define for real x:
[tex]e^{ix}=\cos(x)+i\sin(x)[/tex]
if you put in [itex]x=\pi[/itex] in the above, then it follows.
The solution is :
<=>eiz+e-iz)=0
<=>e2iz=-1
<=>2iz=πi +2kπi
<=>z=π/2 + kπ
<=>e2iz=-1
<=>2iz=πi +2kπi
Thanks
Multiply [itex]e^{iz}+e^{-iz}[/itex] by [itex]e^{iz}\,.[/itex]
[itex]\displaystyle e^{iz}\left(e^{iz}+e^{-iz}\right)=e^{2iz}+1[/itex]
For the second question: [itex]\displaystyle -1=e^{(\pi i)}e^{2\pi k i}\,.[/itex]
thanks, i know eπi=-1
but the problem is , when i was in exam i was looking at the -1 , how can i know e?, what about the question is -2 , do i need to try it one by one like π/2,π/3...
So you want to know what x solves [itex]e^{z}=-2[/itex]? Without going into complex logarithms, this can be solved as
[tex]-2=2*(-1)=e^{\log(2)}e^{i\pi}=e^{\log(2)+i\pi}[/tex]
So [itex]\log(2)+i\pi[/itex] will be a solution (but it will not be the only one).
This can of course also be found by complex logarithms, but you shouldn't use those until you've seen it.
Polar representation is the key. So let's say in exam, you're given some number like [itex]a+ib[/itex] then this is equal to [itex]r(cos(x)+i \ sin(x))[/itex] which is also equal to [itex]r \ e^{ix}[/itex] So this is how you convert from one form to the other.
So your example of -2 clearly has the same x as for -1, but the only difference is that r is twice as great.
